Script Control - Looping Functionality Question. A Bug Or Brain Fart?
Situation: I've looked over all the scripts in the cloud and haven't seemed to find anything pertaining to looping. So I wanted to write a short tutorial for the community. So the simple loop example went okay, but as I wrote a loop within a loop. I am finding myself a little confused as the the process flow of the following code...
Here is the script:
#Loop With In Loop
Print("Loop with a loop")
$OuterCounter = 3
$InnerCounter = 2
:OuterLoopStep
  If ($OuterCounter >= 0)
    #Execute Outer Loop Command
    Print(">Outer Loop Value: $OuterCounter)
    $OuterCounter = $OuterCounter - 1
    :InnerLoopStep
      If ($InnerCounter >= 0)
        #Execute Inner Loop Command
        Print("Inner Loop Value: $InnerCounter")
        $InnerCounter = $InnerCounter - 1
        Goto (InnerLoopStep)
      Else
        Sleep(3000)
        Goto(OuterLoopStep)
        #Wanted to use EndIf for formality, but not nessecary
  Else
    Print("Finished")
  EndIf
Here is the output of the debugger: Start 2: Print("Loop with a loop") Loop with a loop 3: $OuterCounter = 3 4: $InnerCounter = 2 6: :OuterLoopStep 7: If ($OuterCounter >= 0) 9: Print(">Outer Loop Value: $OuterCounter)
Outer Loop Value: 3 10: $OuterCounter = $OuterCounter - 1 12: :InnerLoopStep 13: If ($InnerCounter >= 0) 15: Print("Inner Loop Value: $InnerCounter") Inner Loop Value: 2 16: $InnerCounter = $InnerCounter - 1 17: Goto (InnerLoopStep) 13: If ($InnerCounter >= 0) 15: Print("Inner Loop Value: $InnerCounter") Inner Loop Value: 1 16: $InnerCounter = $InnerCounter - 1 17: Goto (InnerLoopStep) 13: If ($InnerCounter >= 0) 15: Print("Inner Loop Value: $InnerCounter") Inner Loop Value: 0 16: $InnerCounter = $InnerCounter - 1 17: Goto (InnerLoopStep) 13: If ($InnerCounter >= 0) 18: Else 19: Sleep(3000) 20: Goto(OuterLoopStep) 7: If ($OuterCounter >= 0) 9: Print(">Outer Loop Value: $OuterCounter) Outer Loop Value: 2 10: $OuterCounter = $OuterCounter - 1 12: :InnerLoopStep 13: If ($InnerCounter >= 0) 18: Else 19: Sleep(3000) 20: Goto(OuterLoopStep) 7: If ($OuterCounter >= 0) 9: Print(">Outer Loop Value: $OuterCounter) Outer Loop Value: 1 10: $OuterCounter = $OuterCounter - 1 12: :InnerLoopStep 13: If ($InnerCounter >= 0) 18: Else 19: Sleep(3000) 20: Goto(OuterLoopStep) 7: If ($OuterCounter >= 0) 9: Print(">Outer Loop Value: $OuterCounter) >Outer Loop Value: 0 10: $OuterCounter = $OuterCounter - 1 12: :InnerLoopStep 13: If ($InnerCounter >= 0) 18: Else 19: Sleep(3000) 20: Goto(OuterLoopStep) Here's where my confusion starts. Any ideas? Am I missing something obvious? 7: If ($OuterCounter >= 0) 10: $OuterCounter = $OuterCounter - 1 12: :InnerLoopStep 13: If ($InnerCounter >= 0) 18: Else 19: Sleep(3000) 20: Goto(OuterLoopStep) 7: If ($OuterCounter >= 0) 10: $OuterCounter = $OuterCounter - 1 12: :InnerLoopStep 13: If ($InnerCounter >= 0) 18: Else 19: Sleep(3000) 20: Goto(OuterLoopStep) 7: If ($OuterCounter >= 0) 10: $OuterCounter = $OuterCounter - 1 12: :InnerLoopStep 13: If ($InnerCounter >= 0) 18: Else 19: Sleep(3000) 20: Goto(OuterLoopStep)
and on and on the loop executes...
#17
Wow, that will be better then a lazier light show at a Pink Floyd concert!
#18
Compiler's condition tree fixed - sorry for the delay:)
# Loop With In Loop
$OuterCounter = 3
$InnerCounter = 2
:OuterLoopStep
IF ($OuterCounter >= 0)
  Print("Outer Loop Value: $OuterCounter)
  $OuterCounter--
  :InnerLoopStep
  IF ($InnerCounter >= 0)
    $InnerCounter--
  ELSE
    Sleep(1000)
    Goto(OuterLoopStep)
  ENDIF
ELSE
  Print("Finished")
ENDIF
