Inverted Pendulum icon Inverted Pendulum — Balancing controller for Sainsmart v3 (and compatible) robots: PID tuning, real‑time telemetry, angle offset, movement and calibration via ARC. Try it →
Script Help, Doing More Than One Thing At Once
Hey everyone,
Project has 3 Hbridges (robo claw). All controlled serially example...
Sendserial(d0,38400,125)# lft track forward 1 sec sleep(1000)
What I would like to do is while moving forward I would like its body controlled H-bridge to start moving body up so that full body extend will be in process before machine reaches kitchen.
Ive tried something like...
Sendserial(do,38400,125) , Sendserial (d1,38400,70)
But obviously it doesn't work. Im sure its something using control command.... but I haven't got my head wrapped around the whole ControlCommand thing yet. Thanks in advance.
                  Chris
Put it on two lines not one.
Sendserial (d0,38400,125)
You can either run one command after another in the same script (with sleep delays as needed) or run multiple scripts at once.... ARC is pretty much multi-tasking...
sleep(1000)
Sendserial (d1,38400,70) #now send commands to the 2nd roboclaw
@Rich_the_time_traveller beat me to it again....:P
Thanks guys, I may have been misleading though. So I guess what I'm after is start body up 4 seconds into an 8 second travel time with travel time meaning 8 seconds for machine to get from my family room to my kitchen. So maybe something like when sleep equals greater than or equal to 4000 body start lifting and continue lifting during travel.
Sendserial (d0,38400,125) # Start moving
Sleep(4000) # Wait 4 seconds
Sendserial (d1,38400,70) # Raise body
The robot will continue moving during a sleep. The sleep just delays the next line for however many ms is specified.
Ok I see, but what stops main movement at the 8 second mark?
Not to be too much of a bother but can someone provide an example using control commands to? All of my scripting can't be done serially over time (sleep command) once o figure that command out I think I will be golden.
My script has sleep (8000) following main movement command and then serial stop command for both tracks.
Perhaps you are unaware that you can add more than one line of EZ-Script? Press the little PENCIL icon beside the EZ-Script edit box and it will open a window or you to enter multiple lines of code.
As for using the CONTROL COMMAND, there is a tab labelled Cheat Sheet when editing a script. I can see from your profile that you have taken the EZ-Script lesson. I feel it would help if you read the EZ-Script lesson a second time.
