PWM Servo Ramping icon PWM Servo Ramping — Smoothly ramps PWM servos on EZB D0-D23 via Vx-to-Dx mapping for natural, gradual motion without snapping. Try it →
Script Help Please. How To Move Multiple/Relative Servos At The Same Time?
Hello,
i am working on scripts to add to my personality generator, to make wall-e awesome. I am trying to do a , "flashing eyes" script
i have to move 2 servos(one in each eye) to move up and down at the same time. and the "tilt" feature by Glickclick (uses 2 servos to make wall e "tilt forward" by voice control (script)
how can i do that?
i see instructions to move a servo to a specific position, random position between parameters, and even the "if" setting (if a certain servo/sensor hits a certain value the next line in the script is executed)
i cant figure out how to use any of these features to control 2 servos at the same time..
i know of relative servo and multiple servo...but that only helps when using a mouse or keyboard
i cant control relative servos (2 servos) or multiples servos by joystick, voice command or script....
or at least, i cant figure it out....
help please.
If you use the Relative servo control, check the ""Respond to movements from other controls" option in the Config menu.
Now when you move the master servo from a script or something else, it will move all other related servos
!!!!!!!!!!! i didnt see that!!!!!!!!!! thanks!!!!
