SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
Script Recorder Corrupts Ez-script Files
Script Recorder Corrupts Ez-Script Files
After recording movements with the Script recorder when I attempt to save a file I get this error message:
Error saving configuration file. Filename c:\test.ezb Message: There was an error generating the XML document.
Hope this helps,
Bill
Hi Bill, I have the same problem and I think it is the result of a bug that was never resolved. There was a claim that it was related to having too much data - If it has been resolved maybe somebody out there can help.. I gave up on it..;)
There has not been a solution to this issue yet. I've been working on a new file type - which hopefully will lead to a resolution for this. However, i've been working on it for a few days straight because it's about 8,000 lines of code to modify:(
This was a thread for it: https://synthiam.com/Community/Questions/1163
Spain
Glad to know that Dj remembers us, 8000 lines of code should be a lot of work!;)
