Continuous Servo Movement Panel icon Continuous Servo Movement Panel — Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options. Try it →
Ok, I'm stumped. I have tried to do this myself for 3 days, time for help. Is there any reason why a script that works in Windows 7 not work on Windows 10? Below is a script (Credit to Luis Vazquez who wrote this years back, I only added to it) that I can not get to run on my new Windows 10 computer. It is the exact same script on both machines. I know, if it works on one it should work on the other!
The program starts out:
Program says "Oh good, I love to do math."
"What would you like to do ... addition, subtraction, multiplication or division?"
(Your answer) ... "addition"
Program says back "I heard you say addition." "OK, I will give you 5 addition math questions." "Lets begin"
This is where the problem begins!
I does not give a addition question but a division question on the W10 machine?
It is the exact script, copied from one to the other ... lol.
# Initialise Variables
$QuestionNumber = 0
SayWait("Oh good, I love to do math")
:StartTheSquence
SayWait("What would you like to do, addition, subtraction, multiplication or division?")
$MathTypeResponse = WaitForSpeech(10, "Addition", "Subtraction", "Multiplication", "Division")
# Repeat MathTypeResponse
if ($MathTypeResponse = "timeout" )
SayWait("I did not hear what you said.")
SayWait("Lets start over.")
Goto(StartTheSquence)
Else
SayWait("I heard you say " + $MathTypeResponse )
SayWait("Ok, I will give you 5 " + $MathTypeResponse  + " math questions.")
SayWait("Lets begin.")
endif
# Go to math type catagory
if ($MathTypeResponse = "Addition" )
goto(Addition)
ELSEif ($MathTypeResponse = "Subtraction" )
goto(Subtraction)
ELSEif ($MathTypeResponse = "Multiplication" )
goto(Multiplication)
ELSE
goto(Division)
endif
# If MathResponse was addition.
:Addition
$FirstAdditionNumber = GetRandomUnique(0,5)
$SecondAdditionNumber = GetRandomUnique(0,5)
$AdditionAnswer = $FirstAdditionNumber + $SecondAdditionNumber
:loop
$QuestionNumber = $QuestionNumber + 1
if ($QuestionNumber = 6)
SayWait("That was 5 " + $MathTypeResponse + "questions.")
SayWait("Would you like to start over again?")
$StartOverResponse = WaitForSpeech(10, "No", "Affirmative", "Okay", "Yeah", "Negative", "Maybe", "Yes" )
Goto(StartOverQuestion)
endif
SayWait("What is " + $FirstAdditionNumber + " plus " + $SecondAdditionNumber )
sleep(1000)
$AdditionResponse = WaitForSpeech(20, "0","1","2","3","4","5","6","7","8","9","10")
SayWait("You said" + $AdditionResponse)
if ($AdditionResponse  == $AdditionAnswer)
SayWait("Good job! Yes " +  $AdditionAnswer + " is the correct answer")
goto(Addition)
Else
SayWait("Sorry " + $AdditionResponse + " is not correct. please try again.")
sleep(1000)
goto(loop)
endif
# If MathResponse was subtraction.
:Subtraction
$FirstSubtractionNumber = GetRandomUnique(5,10)
$SecondSubtractionNumber = GetRandomUnique(0,5)
$SubtractionAnswer = $FirstSubtractionNumber - $SecondSubtractionNumber
:loop
$StartOverResponse = WaitForSpeech(20, "No", "Affirmative", "Okay", "Yeah", "Negative", "Maybe", "Yes" )
endif
SayWait("what is " + $FirstSubtractionNumber + " minus " + $SecondSubtractionNumber )
sleep(1000)
$SubtractionResponse = WaitForSpeech(20, "0","1","2","3","4","5","6","7","8","9","10")
SayWait("You said" + $SubtractionResponse)
if ($SubtractionResponse  == $SubtractionAnswer )
SayWait("Good job! Yes " +  $SubtractionAnswer + " is the correct answer")
Goto (Subtraction)
else
SayWait("Sorry " + $SubtractionResponse + " is not correct. please try again.")
sleep(1000)
goto(loop)
endif
# If MathResponse was multiplication.
:Multiplication
$FirstMultiplicationNumber = GetRandomUnique(1,5)
$SecondMultiplicationNumber = GetRandomUnique(0,5)
$MultiplicationAnswer = $FirstMultiplicationNumber * $SecondMultiplicationNumber
:loop
endif
SayWait("what is " + $FirstMultiplicationNumber + " times " + $SecondMultiplicationNumber )
sleep(1000)
$MultiplicationResponse = WaitForSpeech(20, "0","1","2","3","4","5","6","7","8","9","10","12","15","16","20","25")
SayWait("You said" + $MultiplicationResponse)
if ($MultiplicationResponse  == $MultiplicationAnswer)
SayWait("Good job! Yes " +  $MultiplicationAnswer + " is the correct answer")
Else
SayWait("Sorry " + $MultiplicationResponse + " is not correct. please try again.")
sleep(1000)
goto(loop)
endif
# If MathResponse was division.
:Division
$FirstDivisionNumber = GetRandomUnique(2,6)
$SecondDivisionNumber = GetRandomUnique(1,2)
$DivisionAnswer = $FirstDivisionNumber / $SecondDivisionNumber
:loop
endif
SayWait("what is " + $FirstDivisionNumber + " divided by " + $SecondDivisionNumber )
sleep(1000)
$DivisionResponse = WaitForSpeech(20, "0","1","2","3","4","5","6","7","8","9","10","12","15","16","20","25")
SayWait("You said" + $DivisionResponse)
if ($DivisionResponse  == $DivisionAnswer)
SayWait("Good job! Yes " +  $DivisionAnswer + " is the correct answer")
goto(Division)
Else
SayWait("Sorry " + $DivisionResponse + " is not correct. please try again.")
sleep(1000)
goto(loop)
endif
#Halt()
# Start over response
:StartOverQuestion
if ($StartOverResponse = "Yes" )
goto(Yes)
ELSEif ($StartOverResponse = "No" )
goto(No)
ELSEif ($StartOverResponse = "Affirmative" )
goto(Yes)
ELSEif ($StartOverResponse = "Okay" )
goto(Yes)
ELSEif ($StartOverResponse = "Yeah" )
goto(Yes)
ELSEif ($StartOverResponse = "Negative" )
goto(No)
ELSE
goto(StartTheSquence)
endif
Return()
Halt()
:Yes
Halt()
:No
SayWait("I enjoyed doing math with you.")
SayWait("Maybe we can do it again soon.")
HALT()
So you told "division" but it went to the behaved as if it heard "addition"? There are not program errors, it just behaves differently?
On your Win7 machine, did you need to code in Speech Recognition setting $MathTypeResponse because I don't see where it would get set otherwise? Did you just copy the script from your Win7 machine or the enter project? I feel like your are missing something else for the project.
@HerrBall
The script has been fixed:
:StartTheSquence
$QuestionNumber = 0
SayWait("What would you like to do, addition, subtraction, multiplication or division ?")
# ptp: changed the phrases to lowercase
$MathTypeResponse = WaitForSpeech(10, "addition", "subtraction", "multiplication", "division")
if ($MathTypeResponse = "timeout")
ELSE
endif
# ptp: compare lowercase phrases
if ($MathTypeResponse = "addition")
  goto(Addition)
ELSEif ($MathTypeResponse = "subtraction")
  goto(Subtraction)
ELSEif ($MathTypeResponse = "multiplication")
ELSE
  goto(Division)
endif
:Addition
:addition_loop
  SayWait("That was 5 " + $MathTypeResponse + " questions.")
  # ptp : changed to lowercase
  $StartOverResponse = WaitForSpeech(10, "no", "affirmative", "okay", "yeah", "negative", "maybe", "yes")
endif
sleep(1000)
SayWait("You said " + $AdditionResponse)
if ($AdditionResponse = $AdditionAnswer)
  goto(Addition)
ELSE
  sleep(1000)
  goto(addition_loop)
endif
:Subtraction
:subtraction_loop
  $StartOverResponse = WaitForSpeech(20, "no", "affirmative", "okay", "yeah", "negative", "maybe", "yes")
endif
sleep(1000)
SayWait("You said " + $SubtractionResponse)
if ($SubtractionResponse = $SubtractionAnswer )
  Goto(Subtraction)
ELSE
  sleep(1000)
  Goto(subtraction_loop)
endif
:Multiplication
:multiplication_loop
endif
sleep(1000)
SayWait("You said " + $MultiplicationResponse)
if ($MultiplicationResponse = $MultiplicationAnswer)
  Goto(multiplication)
ELSE
  sleep(1000)
  goto(multiplication_loop)
endif
:Division
:division_loop
endif
sleep(1000)
SayWait("You said " + $DivisionResponse)
if ($DivisionResponse = $DivisionAnswer)
  goto(Division)
ELSE
  sleep(1000)
  goto(division_loop)
endif
  # Halt()
:StartOverQuestion
if ($StartOverResponse = "yes")
  goto(Yes)
ELSEif ($StartOverResponse = "no")
  goto(No)
ELSEif ($StartOverResponse = "affirmative")
  goto(Yes)
ELSEif ($StartOverResponse = "okay")
  goto(Yes)
ELSEif ($StartOverResponse = "yeah")
  goto(Yes)
ELSEif ($StartOverResponse = "negative")
  goto(No)
ELSE
endif
Return()
Halt()
:Yes
Halt()
:No
HALT()
EDIT 1: Changed phrases and comparison to lowercase EDIT 2: Replaced == with = EDIT 3: Multiple loop tags e.g. :loop
@HerrBall,
EZ-Script help:
Quote:
WaitForSpeech( timeOut Seconds, phrases ) Pauses and waits for one of the specified phrases to be spoken. Returns the phrase that was spoken in lowercase. Will return "timeout" if no word is detected in the specified timeout length. Example: WaitForSpeech(30, "Yes", "No") Example: $value = WaitForSpeech(30, "Yes", "No")
So the 1 Million dollar question: why it works on Windows 7 ?
I presume DJ's added the lowercase information to the documentation after finding out the behavior.
ARC uses the System.Speech.Recognition API (SAPI) when a sentence is recognized the SpeechRecognized event is fired with a specific arguments SpeechRecognizedEventArgs one of the properties is the Text recognized.
If you read carefully (between the lines) https://msdn.microsoft.com/en-us/library/system.speech.recognition.recognizedphrase.text(v=vs.110).aspx
Quote:
Gets the normalized text generated by a speech recognizer from recognized input.
So what is a normalized text ?
https://msdn.microsoft.com/en-us/library/system.speech.recognition.replacementtext(v=vs.110).aspx
Quote:
Speech normalization is the use of special constructs or symbols to express speech in writing.
For example, suppose that this is recognized text:
"july four at twelve thirty one PM, I bought one point six kilograms of fish for fourteen dollars and six cents, at the pike place market in seattle washington nine eight one two two"
This is the same text after normalization:
"July 4 at 12:31 PM, I bought 1.6 kg of fish for $14.06, at the pike place market in Seattle WA 98122"
So what this means ? The Speech engines makes adjustments to the recognized text and the result can be different or slight different e.g. (Lowercase)
I believe windows 7 and windows 10 handle the recognition differently.
Do you feel Lucky ?
I tried this script out, if you give a wrong answer in Subtraction, Multiplication or Division, then the rest of 5 questions are Addition questions. Is it suppose to do that?
fixed script or the original script ?
What you mean wrong answer in Subtraction, Multiplication, Division ? You can only get out saying the operation or timeout.
I ran the fixed script. I then selected Division questions and it said it would ask me 5 division questions. I gave the wrong answer to one of the questions (just to see what would happen) and the rest of the 5 questions were addition questions not division questions.
@Bob,
That is another bug! duplicate loop statements. I'll fix
