User Defined Function Example icon User Defined Function Example — Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent. Try it →
Resolved Resolved by Rich!
The way I understand it, scripting is a sequential command set to move a series of servos or just one through gyrations and positions of all sorts. At least that's what I surmise I could be wrong. Can someone guide me thru the process to accomplish this with the new version of ARC.
Scripting hasn't changed since the older look of ARC other than the syntax and some new commands added.
Scripting is powerful, it can control everything connected to the EZ-B and control any controls in ARC, it can also read from any digital, analogue or I2C ports.
If you check my posts I produced an introduction to scripting which touches on part of what is possible through scripting, also checking the scripting specific section of the forums will show many scripts, all easy to understand and walk through including the popular "Ping Roam" script I produced.
If you let me know exactly what it is you want to achieve I can help with the scripting.
Wow, what a wealth of information thank you for your contribution!
Rich did a great job, this thread is closed!
