HTTP Server icon HTTP Server — Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution. Try it →
Servo(1.D2, 180)
0.d1 = EZB board 0 digital port 1 1.D2 = ARC board 1 digital port 2 And so on
@merne Yeah - My question is not how to address the port on the board (once it is running). That's simple.
Can I CONNECT to Board 1 with CODE?
Can you give an example. are you asking if you can use ControlCommand to connect to board 1 if you have not manually push the connect button?
Controlcommand("connection", Connect1)
This is listed on the tab " cheat Sheet" when you open a script
Hope this is what you are asking
Cheers
BRAVO! (partly)
Interesting... Board 1 connected, executed it's Init Script, and when finished, the Init Script for Board 0 did NOT continue executing.
Bad Dog. Is there a way to get the rest of the InitScript for Board 0 to complete?
#Board 0 Script: SayEZB("Initializing Board Zero") Sleep(2000) ControlCommand( "Connection", "Connect1" )
#do the rest of my init routines for Board 0 here (is not happening...)
You need to increase the sleep command longer, thats what the sounds like. I believe you can also use a wait command to. Can you post a sample script?
First, use the [ code ] formatters if you wish to display code
second, use the SayEZBWait() command if you want to wait for it to speak.
#Board 0 Script:
SayEZBWait("Initializing Board Zero")
# do some other stuff
The EZ-Script manual is along the right when editing scripts. Here's a screenshot
When you see something BLUE in someones reply, you can click on it. For example the Cheat Sheet is in blue. Click on it so you can read about it. Also, ControlCommand is in blue, click on it so you can read about it.
Here is the InitScript running on Board 1 (ps Thank you for your help with this!)
SayEZB("Initializing Board One")
UARTInit( 1, 2, 9600 )
Sleep( 3000 )
SayEZB("Initializing Head and Neck Servos")
#Head Vert
Servo( 1.D0,125 )
ServoSpeed( 1.D0,1 )
SetServoMin( 1.D0,30 )
SetServoMax( 1.D0,165 )
#Head Rot
Servo( 1.D1,125 )
ServoSpeed( 1.D1,1 )
SetServoMin( 1.D1,20 )
SetServoMax( 1.D1,180 )
#Head Side
Servo( 1.D2,145 )
ServoSpeed( 1.D2,1 )
SetServoMin( 1.D2,30 )
SetServoMax( 1.D2,180 )
#Jaw
Servo( 1.D3,105 )
ServoSpeed( 1.D3,1 )
SetServoMin( 1.D3,105 )
SetServoMax( 1.D3,160 )
#EyesV
Servo( 1.D4,95 )
ServoSpeed( 1.D4,1 )
SetServoMin( 1.D4,70 )
SetServoMax( 1.D4,125 )
#EyesH
Servo( 1.D5,105 )
ServoSpeed( 1.D5,1 )
SetServoMin( 1.D5,60 )
SetServoMax( 1.D5,130 )
#Head Vertical Movement
SayEZB("Looking Down")
Servo( 1.D0,30 )
Sleep( 2000 )
SayEZB("Looking Up")
Servo( 1.D0,165 )
Sleep( 2000 )
SayEZB("Looking Ahead")
Servo( 1.D0,125 )
Sleep( 2000 )
#Head Rotation
SayEZB("Looking Left")
Servo( 1.D1,20 )
Sleep( 2000 )
SayEZB("Looking Right")
Servo( 1.D1,180 )
Sleep( 2000 )
Servo( 1.D1,110 )
Sleep( 2000 )
#Head Sidebending
SayEZB("Sidebending Left")
Servo( 1.D2,180 )
Sleep( 2000 )
SayEZB("Sidebending Right")
Servo( 1.D2,30 )
Sleep( 2000 )
Servo( 1.D2,130 )
Sleep( 2000 )
#Jaw Open Close
SayEZB("Opening Mouth")
Servo( 1.D3,160 )
Sleep( 2000 )
SayEZB("Ahhhh")
Sleep( 2000 )
SayEZB("Closing Mouth")
Servo( 1.D3,105 )
Sleep( 2000 )
#Eyes Look Up and Down
SayEZB("Eyes Looking Up")
Servo( 1.D4,125 )
Sleep( 2000 )
SayEZB("Eyes Looking Down")
Servo( 1.D4,70 )
Sleep( 2000 )
SayEZB("Eyes Looking Ahead")
Servo( 1.D4,95 )
Sleep( 2000 )
#Eyes Look Left and Right
SayEZB("Eyes Looking Left")
Servo( 1.D5,130 )
Sleep( 2000 )
SayEZB("Eyes Looking Right")
Servo( 1.D5,60 )
Sleep( 2000 )
Servo( 1.D5,105 )
Sleep( 2000 )
SayEZB("Completed Initialization, Testing Neo Pixel")
SendSerial( 1.D18, 9600, "W250,0,0,250,0,0")
Sleep( 2000 )
SendSerial( 1.D18, 9600, "C0,0,0")
Sleep( 2000 )
SendSerial( 1.D18, 9600, "S250,0,0,250,0,0")
#END of Board 1 Script - should pass control back to Board 0 calling script...
I edited your post and put [ code ] [/ code ] tags around the code so people can read it
