Script icon Script — Multi-language ARC Script: build, run and debug Blockly, JavaScript, EZ-Script or Python with Intellisense, run/save/load and Roboscratch support Try it →
Germany
Google+ YouTube
Resolved Resolved by WBS00001!
Scripts Dont Work
Hello DJ, follow Scripts dont work: Exec("C:\Windows\Notepad.exe")
Browser("https://www.google.com";)
FileWrite("c:\temp\mylog.txt", "My Variable: " + $x)
FileWriteLine("c:\temp\mylog.txt", "My Variable: " + $x)
And when SpeakRSS is active, I can not stop using a voice command it. The voice control reacts to a command when Peak RSS is active. I will stop the RSS with Spoeak Command.
Thanks
Germany
Google+ YouTube
#17
@CochranRobotics Thank you for your detailed explanation. Even though I have not understood everything with my bad English and with the help of Google Translator certainly correct. Now my problem is aware. So I have to try to find other ways, and I continue programming with the deal to come to a conclusion. I was previously unaware that it is the facts so complex.
#18
@lizpoir
At this point I am not sure I quite understand what you want to do or are having troubles with so let me see if I have it right.
  1. You want to start the robot speaking the contents of an RSS feed with a voice command.
  2. As the robot is speaking the text of the RSS feed, you want to be able to stop it at any time with another voice command.
  3. Currently, you are having problems with the robot speaking the text in the RSS feed. Or you are having problems getting the RSS feed in the first place?
Germany
Google+ YouTube
#19
@WBS00001 My Problem is Number 2 When the robot RSS Speak unresponsive speech recognition, no command and I suspect this is a bug.
Germany
Google+ YouTube
#20
Okay i think its not possible.
Germany
Google+ YouTube
#21
But it is not resolved before I continue every day get an e-mail to.
