Cognitive Vision icon Cognitive Vision — Microsoft Cognitive Vision integration for ARC: real-time object, face, emotion detection, OCR, confidence data and script-triggered robot actions. Try it →
Sdk Support For Connecting To Ez-B V4
Hi all,
I'm looking for assistance in using the currently available SDK to connect to an EZ-B v4 directly.
I already posted a question on the tail of this thread
... but realized someone had pretty much asked the same question here:
Vb4 Connect Obj Asks For A Password
... unfortunately the thread concluded ambiguously.
The short of it is this. When building and running the SDK sample files in either CSharp or VB using EZ-SDK Version 2014.01.21.00 and attempting to connect to an EZ-B v4 we can set (or the User Control can prompt for) the EZB_Connect.Port and EZB_Connect.TCPPassword.
In my case I am using AP mode and 192.168.1.1:23 and dismissing the password dialog. The EZ-Bv4 seems to respond to the connection attempt with a red light and an audio ding - but then disconnects shortly after with the following debug output:
Quote:
12/08/2014 9:18:49 PM - 12/08/2014 9:18 PM - Attempting connection on 192.168.1.1:23 12/08/2014 9:18:49 PM - 12/08/2014 9:18 PM - Connected to 192.168.1.1:23 12/08/2014 9:18:49 PM - 12/08/2014 9:18 PM - EZ-B reports EZ-B v4 OS 12/08/2014 9:18:49 PM - 12/08/2014 9:18 PM - Welcome to EZ-B v4 Beta! 12/08/2014 9:18:58 PM - 12/08/2014 9:18 PM - Comm Err: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.IO.Stream.ReadByte() at EZ_B.EZB.(Byte , Byte[] ) 12/08/2014 9:18:58 PM - 12/08/2014 9:18 PM - BbytesToExpect: 12 12/08/2014 9:18:58 PM - 12/08/2014 9:18 PM - ? Received: 12/08/2014 9:18:58 PM - 12/08/2014 9:18 PM - Disconnected 12/08/2014 9:18:58 PM - 12/08/2014 9:18 PM - EZ-B v4 ID: 0-0-0-0-0-0-0-0-0-0-0-0 12/08/2014 9:18:58 PM - 12/08/2014 9:18 PM - Connected
From the responses on the other threads and SDK-Docs I am a little confused, specifically:
  1. The SDK help says the EZ_Connect object is for making bluetooth connections, however entering an IP address for the Port seems to get a rise out of the EZ-Bv4 so I assume it supports direct IP connections to the EZB-V4 from a standalone app. Is that correct?
2)... or have I miss-understood, do standalone SDK based apps have to connect through an instance of ARC?
  1. Should EZ-SDK Version 2014.01.21.00 support EZ-B V4 currently?
  2. If this is an issue with the SDK and it is already known. Any idea when an update will be available?
  3. Can you suggest a workaround? (ex. perhaps if I make an add-on to ARC to leverage its ability to establish a connection)
Sorry to sound needy. I am just excited to get started on a complex behaviour that lends itself more to a custom code written on the SDK.
Thanks, Daniel (CodedByATool)
1.Ehh, yes...no....ehhhh. It looks like you more or less pinged it. It said "I'm here"..."what's the secret hand shake"..."error, that's not the right hand sake"
  1. No. the SDK should* allow you to connect to your EZb and you do not need to use the ARC
  2. I believe DJ stated in the other thread that a new release would be forthcoming
  3. The EZ-Robot staff would need to answer that
  4. Probably not. Even though you appear to have made a "ding" connection to communicate effectively you need the full connection string and password which as stated by DJ in the previous thread is not in the SDK currently. With out that, proper communication are not going to be effective.
I can understand your excitement as a coder. As a fellow coder, I recommend two things,
  1. Send a message to the EZ-Robot staff via "contact us" to remind them the SDK needs updated as DJ stated and in forum thread 6005 (the squeaky wheel tends to get the grease).
  2. I would invest some time playing with controls in the ARC. Try to push the limited of what the ARC can do for you. This will greatly impact your development process because you'll need to experience what ARC can do (in my opinion) before using the SDK. And while you are testing make your self a list of what works well and what you think you could improve and what does not provide you enough control. You'll end up with a task list and see what EZb can do out of the box with ARC. :)
Get the latest EZ-SDK which is 2014.06.22.00 - it has a few changes to the one you are using.
Wahey! The SDK download page has updated since the 12th. and .... ... it works great!
EZ-B V4 is quite literally rolling now..
Cheers.
PS> C# Tutorial 1 disables the panel with the Forward/Stop/Reverse buttons and doesn't enable them. I added the OnConnect/Disconnect event handlers I presume it was meant to have - might be nice to fix for the next release.
