Uzbekistan
Hello DJ! I want to thank you for your support! I was able to extract image frames from the camera in real time. I also managed to make a websocket client that sends a stream of frames to my django server.
This is your modified by me code:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.IO;
using System.Runtime.InteropServices;
using ARC;
using System.Threading;
using System.Net.WebSockets;
namespace CameraCapture {
  public partial class MainForm : ARC.UCForms.FormPluginMaster {
    Configuration _config;
    ARC.UCForms.FormCameraDevice _cameraControl;
    bool _isClosing = false;
    [DllImport("kernel32.dll", SetLastError = true)]
    [return: MarshalAs(UnmanagedType.Bool)]
    static extern bool AllocConsole();
    CancellationTokenSource source = new CancellationTokenSource();
    ClientWebSocket wsClient = new ClientWebSocket();
    public MainForm() {
        InitializeComponent();
      // show a config button in the title bar. Set this to false if you do not have a config form.
        ConfigButton = true;
        detach();
    /// Set the configuration from the project file when loaded.
    /// We'll extract the _config class that's from the project file.
    public override void SetConfiguration(ARC.Config.Sub.PluginV1 cf) {
        _config = (Configuration)cf.GetCustomObjectV2(typeof(Configuration));
        base.SetConfiguration(cf);
    /// When the project is saving, give it a copy of our config
    public override ARC.Config.Sub.PluginV1 GetConfiguration() {
        _cf.SetCustomObjectV2(_config);
        return base.GetConfiguration();
    /// The user pressed the config button in the title bar. Show the config menu and handle the changes to the config.
    public override void ConfigPressed() {
      using (var form = new ConfigForm()) {
        form.SetConfiguration(_config);
        if (form.ShowDialog() != DialogResult.OK)
          return;
        _config = form.GetConfiguration();
    private void button1_Click(object sender, EventArgs e)
        if (_cameraControl == null)
        attach();
        else
            detach();
    void detach()
        if (_cameraControl != null)
            if (!_isClosing)
                ARC.Invokers.SetAppendText(tbLog, true, "Detaching from {0}", _cameraControl.Text);
            _cameraControl.Camera.OnNewFrame -= Camera_OnNewFrame;
            _cameraControl = null;
        if (!_isClosing)
            ARC.Invokers.SetText(btnAttach, "Attach");
    void attach()
        detach();
        Control[] cameras = ARC.EZBManager.FormMain.GetControlByType(typeof(ARC.UCForms.FormCameraDevice));
        //Task returnedTask = OpenConnectionAsync();
        if (cameras.Length == 0)
            ARC.Invokers.SetAppendText(tbLog, true, "There are no camera controls in this project.");
            return;
        _cameraControl = (ARC.UCForms.FormCameraDevice)cameras[0];
        _cameraControl.Camera.OnNewFrame += Camera_OnNewFrame;
        ARC.Invokers.SetAppendText(tbLog, true, "Attached to: {0}", _cameraControl.Text);
        ARC.Invokers.SetText(btnAttach, "Detach");
    void Camera_OnNewFrame()
            return;
        try
            using (Graphics g = Graphics.FromImage(_cameraControl.Camera.GetOutputBitmapManaged))
                using (MemoryStream ms = new MemoryStream())
                    _cameraControl.Camera.GetOutputBitmapManaged.Save(ms, System.Drawing.Imaging.ImageFormat.Jpeg);
                    // here is the image array
                    byte[] byteArray = ms.ToArray();
                    SendAsync(byteArray, source.Token);
        catch (Exception eX)
            Invokers.SetAppendText(tbLog, true, eX.ToString());
            detach();
    public async Task OpenConnectionAsync(CancellationToken token) {
        Uri serverUri = new Uri("ws://127.0.0.1:8000/ws/socket-server/");
        await wsClient.ConnectAsync(serverUri, source.Token).ConfigureAwait(false);
    public async Task SendAsync(byte[] byteImage, CancellationToken token)
        try
                await wsClient.SendAsync(new ArraySegment(byteImage), WebSocketMessageType.Binary, true, source.Token);
                Console.WriteLine(wsClient.State);
        catch (Exception eX) {
            Console.WriteLine(eX);
    private void MainForm_Load(object sender, EventArgs e)
        AllocConsole();
        OpenConnectionAsync(source.Token);
This websocket server part on django:
import json
import cv2
from channels.generic.websocket import WebsocketConsumer
import os
bytes_arr = 0
class WSConsumerTest(WebsocketConsumer):
    def connect(self):
        self.accept()
        self.send(text_data = json.dumps({
            'message': 'created_socket',
        print('success connection')
    def receive(self, text_data=None, bytes_data=None):
        global bytes_arr
        if (bytes_data != None):
            bytes_arr = bytes_data
        elif(text_data != None):
            self.send(bytes_data=bytes_arr)
Next, I output the frame stream to the browser in real time in the same way, but unfortunately here for some reason I can’t publish the html / js code, I don’t know why to be honest. The next step is server-side image segmentation and automatic motion control of the robot based on segmented image analysis. If you are interested in the further fate of the development, I can publish further results.
Best wishes!
That’s great! Nice work in such a short period of time. Please keep me updated. I enjoy watching progress of what ppl make
