Ubtech Alpha 1 Bluetooth icon Ubtech Alpha 1 Bluetooth — Bluetooth control for UBTech Alpha1 servos via ARC: map Vx to servo IDs, enable servos, and integrate with ARC movement & LEDs. Try it →
Serial Gps For Ez-B
Has anyone looked at something like the Locosys LS20031 as a serial device attached to the EZ-B? Requires 3.3V. Output is to a TTL-level serial port. IT outputs the data in more than 6 different National Marine Electronics Association (NMEA) GPS sentences (user selectable) at a rate of up to 10 Hz.
