Stream All The Video Sources icon Stream All The Video Sources — Stream video from any URI/protocol (RTMP, RTSP, HTTP, UDP, etc.) to a selected ARC camera device for real-time network feed playback. Try it →
Serial Toolbox Plugin
@PTP
I have read over the tutorial on making plugins and it was very good and helpful. I am looking to do a plugin using the serial port on the ezb to communicate with an arduino type board to communicate back and forth with various sensors, lcd's, etc.
I was wonering if I could get your source code for the serial toolbox plugin to learn from regarding serial port communications with ezb, etc. I am also taking a course on c# but there is nothing like actual examples of code when it comes to communicating with hardware serial ports. Most all courses don't go into this type of coding. Thanks much....Rick. :):)
reserved 5
Twitter
Thanks for putting this together. One area I was struggling with when talking to the UART was sending multiple commands at once and waiting for answers to come back. I have to do it one command at a time. Send request, wait for aknowledgment, and then act. Example I am reading the position of a dozen servos and then mirror the servos with a second set to mirror the position of the first set of Servos. Unfortunately this means I have to send individual get location requests, wait for acknowledgement, process data checking for CR LF and then send to new Servo. Then repeat for next one.
What would be better if I could send a command to arduino to say keep checking servo locations if nothing changes don’t talk to me but if one changes send me a messsage.
I haven’t had a chance to get around to this yet but would be nice if we had a way to reduce chatter between two devices.
Nink, if you're creating the application protocol yourself - meaning you get to define the commands and what to expect in response...
So if that is the case, do not terminate. And you generally see some "command packets" have a silly checksum. That's silly in this day of age... specifically with TCP already embedding sanity checks. And to communicate over UART, well... it's pretty difficult in this day of age to have a single byte go unnoticed. Back in the day... and i mean like 20-30 years ago when cpu's were slow and interrupts were rare... that's when sometimes a byte could go unnoticed.
Anyway - the next thing is the command and termination. So yeah, don't terminate. Create a list of commands and their expected response size. That way you can cut the transmission speed and processing significantly.
Take for instance if your command is 1 byte, and your termination is 2 bytes (crlf). That's 3 bytes per transmission. And if your response is 1 byte, but terminated with 2 bytes (crlf) then that's 3 bytes for transmission. That's a total of 6 bytes to do one little thing. If you didn't terminate, and had an expected list of commands and their length, then you'd cut that transmission size by 300%! So if you were to transmit 100 commands, with a CRLF you'd actually be transmitting 300 Bytes vs 100 Bytes. HUUGGE difference with volume! (three times as much...)
Now, we've only reviewed the datasize. We haven't touched on the processing aspect. Part of the discussion is "oh now i have to parse the data blah blah blah". Why do you have to parse data? Never parse data. Parsing data when you should know what to expect is unnecessary. If you're in control of the data, don't design it to be parsed. CPU processing time is a luxury, not a right:D
Have you taken a look at the ez-b communication protocol datasheet? That will give you an idea of how to implement an application protocol of your own.
Here, take a look at this: https://synthiam.com/Tutorials/Lesson/18?courseId=4
While you add to that, let me expand on what an efficient application protocol should look like...
What i recommend is, if you only need to set and receive servo positions, is to use the 7th bit to determine SEND or RECEIVE. That gives you 127 servos you can send or receive to.
So to SEND a command, have it like this...
COMMAND, POSITION (0-127), (0-255) i.e. Move servo 0 to position 50:
# Initialize the port, obviously only do this once upon connection
UARTInit(0, 0, 230400)
DefineArray($DataToSend, 2)
$DataToSend[0] = 0 # servo 0
$DataToSend[1] = 50 # Position 50
UARTWriteBinary(0, 0, $DataToSend )
And to get data back... do something like this...
$DataToSend[0] = 0 + 127 # servo 0. We add 127 to set the last bit to a 1
# No point to probe the ezb to see if data is available. Just read it, it'll block while
# it waits for the read. Your slave should already have that data cached anyway
# so there's no delay in reading.
UARTReadBinary(0, 0, 1, $DataToRead)
print("The servo Position is " + $DataToRead[0])
@DJ, Thanks I agree with you a Tutorial will be more easy to follow and update. I'll finish this thread, and use the user feedback to create a tutorial.
@Nink I'll provide examples how the plugin can help for different scenarios sync and async data responses.
This a text protocol, is not optimal neither bullet proof but it's EZ to debug and test and improve but there some limitations: message size and text only.
So if you want to send sound bytes or bitmap bytes you need to develop a custom protocol similar to the EZ-Robot.
I've a custom robot, and I'm using multiple mini controllers to solve different problems (time sensitive) and HID (Human Input Devices) related e.g.
  1. multiple push button keypad
  2. multiple leds
  3. oled 128x64
  4. other sensor devices.
I like the concept of building blocks, so each problem is solved with a micro-controller, but in the end they need to communicate with a master controller EZB or a Host.
Each device sends and receives data sync and async, so I2C does not fit, so I'm using serial (tx,rx).
If each device requires a serial port, soon or later you will run out os UART ports.
So each device has two or more serial devices, and they relay/route the messages using their serial ports, so you can have a Host with a single port communicating with N inline serial devices or you can have a network with multiple nodes (redundant paths or alternative more/less hops)
I couldn't find anything simple (Library) to use so this is another mini project i'm working on.
#15
Okay - now last part of the lesson:D
Once you have a good working EZ-Script that sends and receives your servo commands, turn those into EZ-Script functions as a plugin. The neat thing about ARC is you can extend the capabilities, including ez-script. So you can create a plugin that registers the commands...
# Move servo 0 to position 50
SetMyCustomServoArduinoThingy(0, 50)
# Get servo 2's position
$x = GetMyCustomServoArduinoThingy(2)
You can do this by following this part of the plugin tutorial: https://synthiam.com/Tutorials/UserTutorials/146/22
#16
ptp, add an address byte at the beginning of each command - that way all other controllers ignore the command if it's not addressed to them.
something like..
[ADDRESS], [COMMAND], [DATA]
