EZ Chart icon EZ Chart — 4-series bar chart for real-time sensor comparison in ARC; set titles, values, RGB bar colors and conditional coloring via EZ-Script. Try it →
A servo moves into the position you specify. If you specify position 13, it moves to 13:)
Every control has a ? (question mark) next to the X (close) button. If you press the ?, you will be directed to a tutorial page that explains how to use the control. There is a video for almost every control. The servo controls tutorials, and Auto Position control tutorial will give you more information on how they work:)
It's good to know that a servo simply moves into the position that you specify.
Auto Position is not just for centring, you can use it to build frames for animations, such as moving arms up or down, wiggling fingers, facial expressions etc.
As far as I know you can add all 20 digital ports.
To centre all servos use the servo calibration script (attached)ServoFullRangeWarmup-634899825363427735.ezb
LOL Rich, we're always seconds away from each other replying to questions:)
