Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
Hitec makes a continuous rotation servo, so does Parallax... Hoverer, the servos here in the ez robot store are just as good and they can handle 7.4v....You may have to go to a geared DC motor to get the kind of torque you are after, though....
Other than dynamixel, you won't find any better servo than ours. The servos we sell are modified for even higher quality than the standard version.
I don't see where you sell just a servo. Everything I see has an EZ Bit with it. I also don't see any micro servos or heavy duty ones. I am in need of all three but delivery is over a month or maybe even more. I would really like to get started before that. Am I missing something.
Philippines
@DJSures: there's only two type of servo in EZstore if there is 25kg-cm i wont go to other store...:D
None of the stores servos produce that much torque.... This one does but it is quarter scale size ...Quater scale servo I will say it again, use a geared DC motor instead. They are much better suited for drive wheels.... Servos were originally never meant for 360 deg rotation.... As drive wheels they won't last as long as geared DC motors will....
EDIT the link above is for a giant sized servo not quarter sized....
