I was running JD successfully last night, up until the time I had to put him on charge. Charged up the battery, disconnected after the charge. Tonight after powering him up as usual, I found one of the servo's (Port D5, his left 'forearm') was unresponsive.
Symptoms are: the servo doesn't move when instructed. The servo is able to be rotated by hand even when it should be 'locked' in place (similar to it's powered down state in battery saver mode). There's no change if I place him in the 'calibrate' position. All other servo's are in their normal calibrated position.
There was no smoke and no buzzing from the servo last night prior to powering JD down. I have disconnected the servo from the port and reconnected it as well. There are no obvious signs of the wires at either end being frayed or unusual.
I am wondering if there's anything else I can try, or if this is an indication of a dead servo? I received JD just over 2 weeks ago.
Any advice would be appreciated. Thanks.
Sorry forgot to add the link. https://www.arxterra.com/servo-protection-methods-trade-off-study/
@Richard,
regards, KC.
Along with setting the servo speeds in the INT script, also set your Min, Max positions for the servos. Foe example:
@Dave,
regards, KC.
Good info, I think I will make the same program changes as well.
I 3D printed a JD and used some Tower Pro MG996R servos I had used for a hexapod robot I built in the past. Only to find out that the servos turn the opposite direction as the EZ-Robot servos. Just a heads up when using other manufactures servos.
RichardZ
There's also a box inside of the servo control that you can check that will reverse the circles easily and simply.
@Dave Thanks Dave, I looked for a check box that would reverse it in the JD Project but could not find it. I assume I need to setup a servo profile in the project . Is that correct?
No, all you need to do is install a servo control. Then for the servo you want to reverse just open the control by clicking on the gear symbol and assign the port and ezb board to that servo. In that same window you should see a box to check for reversing this servo. I'm not sure if you can do the same thing from a servo profile. Good luck and have fun.
