Smart Variable Watcher icon Smart Variable Watcher — Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length Try it →
Servo Causes Ezb V4 To Reboot
I purchased the Developer kit in hopes of trying out the Teddy Ruxpin project. I have the EZB v4 powered by the 6 rechargeable batteries like recommended; however, if I attach a servo to it, it will reboot if the servo attempts to move more that a few degrees. Is the rechargeable batteries only powerful enough to turn on the EZB? Do I need something else to actually run the servos that comes with the kit?
@ptp Thank you very much for the details. This helps a lot!
