When running my servo initialization in the connection script I am able to set position and speed just fine. I noticed that when first powering up before the connection init script runs the tilt and rotation servos both always go to the "0" degree position which is a bit awkward.
I read the servo positioning and speed setting tutorial and it mentions about a reverse init routine before powering down to set the servos in the position that you want them in at power down. This could be done via a button in the mobile app via scripting. At the end it is implied as far as I can tell from reading the tutorial, that once this is done and power is applied again (and before the init script is run) the servos would remain in the same positions as they were when power was removed. This doesn't seem to be the case however.
Wondering if there is a way to keep the servos in the same position at powerup (before the int script is executed) as they were at power down? Why do the servos when power is applied always go to the zero degree position?
I noticed when you use the servo slider in the mobile app, that when you first move the servos after poweup no matter what position the servos are in they go to 0 degree position and then start to function normally.
Any clarification on these issues is much appreciated....Rick
Glad this has helped.
