Joystick (Xinput) icon Joystick (Xinput) — XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts. Try it →
I just uped the amperage on my batteries and put in a cooling fan. Works great with my 30 servos that I am running. Four are heavy duty.
Sweden
How did you "uped the amperage"? And how did you connect it?
And do you have servo controller cards connected to the ez-b since 30 servos are more ports than it has?
Thanks!
I bought a battery with more amperage. I use the EZ-B to controll all the servos. I connect them directly to the EZ-B and I have 2 EZ-B's on board.
Sweden
How did you connect the external power?
I use a 11.1 volt 2200 mAh Li-po battery conected directly to the EZ-B so I am only getting 5 volts to my servos. If you want Higher Voltage connect the external battery to the + and - on your servo and the signal wire to the EZ-B. You should also ground the two batteries together.
