ADC Value icon ADC Value — Display ADC port voltage and 0-255 linear values (0-3.3/5V); configurable board/port, units, multiplier and sample interval. Try it →
Italy
Hello and first of all, scuse me for my bad english.
I am trying to use servos for the movement of my robot, but i see a bad thing. When servos goes in position i set, they have a vibration..........
For example, i set a servo in 60% position. It goes to the position and it start "buzzing".......
Do you have same problem? I am thinking using motors and not servos, but it's a difficult way. If i have many servos, i will have many "buzzing", so, my robot will be very bad..........
Can someone suggest me a solution? Thank you very much and scuse me for my bad english.
Ema from Italy
Buzzing usually indicates it is holding a load and that load may be near to, or even over the maximum torque of the servo.
What is the maximum torque rating of the servo, and what are the weight and length of the part the servo is moving? Did you carry out the relevant calculations?
Hello ODT , if you have digital servos they Humm or buzz when they are on. It is because the controller pulses 300 times a second and that makes an audible tone.
odt, Buzzing happens when there is a load present, like asking to position out of range or after the desired range is completed, you can try releasing the load to the individual servo# or perform a #Release All ReleaseAll(0) command. This will also increase your battery life. Maybe you asking a load above the capability of the servo, like mentioned by Rich. Steve S
Italy
Thank you for the reply. The servos buzz even with no load, when they are 'on'. I have tried to change servos, but all the servo i have, do an audible tone and a little vibration.
If it is ok, like jstarne1 has explain, i don't like the thing very much because having many servos, i will have many audible tone.... The way 'detaching' servos, is not a good idea because, for example, detaching the head servo, the head will roll down... I was thinking using motors with encoder, but i don't like encoders very much. Do someone has some other ideas?
Thank you
Ema
DC Motors are very quite. Sadly EZB doesn't support encoders though. You can use pots attached to the ADC ports of EZB for feedback for position control.
If you want to use encoders you can use a Kangaroo board to take the load off of EZB and handle the encoder functions. www.dimensionengineering.com/products/kangaroo
Italy
Can you explain please what is a "pot"?
Ema, mine buzz too when they are at their max rotation limits (load or no load)... My guess is they are pressing against their stops... Or in my case, possibly due to cheap servos...;)
A pot is a potentiometer which is a variable resistor.
