Something like this may give you some help too. I use these two scripts attached to joystick buttons to open and close a claw as long as I am pressing the button. You could adapt the function to your needs but not exceed the min or max values.
#close
RepeatWhile(GetServo(D23) < 90)
  ServoUp(D23, 2)
Sleep(150)
EndRepeatWhile
#open
RepeatWhile(GetServo(D23) > 34)
  ServoDown(D23, 4)
Sleep(150)
EndRepeatWhile
I would like to thank everybody. The example code and explanation was just what I needed. What I've noticed is that by running the code this way I have to way for the slewing to complete. Is there a way to do two things at once? Meaning I would like it to go up/down and side/to side, like tracing a W. Any thoughts or suggestions?
Do you mean two servos like a pan/tilt?
If you use something like my last example where you are moving a little at a time in a loop, you would just issue two commands, one to each servo before looping. The commands will execute so fast that they will be simultaneous for all intents and purposes.
Another way you could do it using the example in post #7, is to add another servo command before the sleep() (anything before the sleep will run at the same time).
#Assuming you have servos connected to ports D1 and D2.
#initialize servo speeds
Servospeed(D1,2)
Servospeed(D2,2)
#start your repeating servo commands
:loop
Servo(D1,50)
Servo(D2, #add your MAX servo position here)
Sleep(2000)
Servo(D1,80)
Servo(D2, #add your MIN servo position here)
Sleep(2000)
Goto(loop)
Obviously, change where you want your max positions to go, and as already mentioned, servo speeds, and length of sleeps where you need to.
