Roll Pitch Yaw icon Roll Pitch Yaw — Rotate and position camera or object with roll/pitch/yaw controls; save camera settings; bind or monitor a 3-value EZ-Script array for live rotation. Try it →
Some of my servos work with the servospeed command and some don't. When I run this script
servospeed(d15,5)
servo(d15,1)
sleep(2000)
servospeed(d17,5)
servo(d17,100)
sleep(2000)
servospeed(d16,5)
servo(d16,1)
Only servo d17 runs slow. Both of the other two run at full speed. The servos are the same brand. I thought it was part of the bug but it is still doing it.
Sorry dude, but i can't continue repeating myself. Please re read my reply.
You cannot invert a servo in script. I can't say it any differently.
Your code keeps putting the position to 1, and that's the starting position. So if you change your code to move the servos to position 100, you will see the speed.
This will demonstrate. Keep in mind that you may not wish to push a servo past its limits. Some servos will burn out their motor if you push it too far. Some servos start at position 10, and end at position 90.
# Set servo Speeds
servospeed(d15,5)
servospeed(d16,5)
servospeed(d17,5)
:LOOPSTART
# Move servos to position 90
servo(d15,90)
sleep(2000)
servo(d17,90)
sleep(2000)
servo(d16,90)
sleep(2000)
# Move servos to position 10
servo(d15,10)
sleep(2000)
servo(d17,10)
sleep(2000)
servo(d16,10)
sleep(2000)
goto(LOOPSTART)
Hello again, Just got home from work. I copied your script and tried it and I got the same results. So I copied it and put it into a new control and deleted the onld one and now everything is fine. Thank you for all your help and patients.
:) I knew you'd get it. Never let me down yet!:D
I've been bookmarking and saving any pages that people have posted here hoping it will help me. Yesterday I was thinking that DJ wanted you to go through the motions your self to get it working because you would learn a lot more by your own discovery then if he would have just told you. JW:)
@ DJ: Methinks you snuck one in on us! I don't find :LOOPSTART in the ARC manual; but I entirely get it! Kinda sneaky.....................you're going to teach some of to write code whether we know it or not. I'm back to lurking.................... Really enjoying "High Five". So much more we can do now. I'm at the point where I'm ready to start mounting componets on Gizmo. Next is the batteries and motor driver. BTW On the L289N driver is the ENA and ENB the pins to put the PWM on??????? Will be posting progress photos as I go. I got my Camcorder out yesterday. Believe it or not I'm going to attemp to do a video. Lloyd
#16
@Robotz012248 hey lloyd, great to hear! The scripting manual does mention the LABEL feature..
Quote:
:Label Defines a label for a GOTO() command Example: :My_Label
Goto( label ) Goto a specific :Label location Example: Goto(My_Label)
As for your PWM on the motor controller, connect a Digital I/O Port from the EZ-B to both Enable connections on the LN298. There will be 2 jumpers, 4 pins for the Enable on the LN298. Two of those pins are Enable, and the other 2 are +5. You can verify by using a volt meter of which is which.
