ROS2 Connector icon ROS2 Connector — Bridge ARC to ROS2 via rosbridge: publish/subscribe topics for cameras, servos, ports, NMS, variables, scripts, and movement. Try it →
Servo Synchronization: Servospeed Delay Values
I need to synchronize the servo movements between a EZ-Script and an external device.
ServoSpeed (Dx, speed)
The speed is 0 = (fastest) and 10 (slowest)
Q1: it's possible to know the delays in milliseconds for each speed ?
Servo( Dx, Position)
Q2: When the servo sweeps between current position and a new position is the incremental value 1/-1 or varies per speed ?
Thanks
Just curious... What are you using to power your ezb and servos? Most disconnects are caused by power supply problems...
i'm using a power adaptor 7V, 5A. I only have two servos for testing, but the disconnects are frequent event when idle for a few minutes.
I'm not sure ... i think someone near by me must have some crazy wifi routers i
i'll need to find a solution (i have some ideas is the next step)
How many servos? 5amps is barely good enough for an ezb, camera and maybe 1 servo... I suggest a Lipo or Nimh battery or an power supply rated for at least 20amps...
If you pull too many amps from a under rated power supply (moving too many servos at once) the ezb will "brown out".. This is a condition where the voltage drops below 4.5V temporarily staving the ezb of power... It will disconnect and reboot when this happens... This is what may be causing your disconnects...
edit I see you have two servos... You have a poer problem my friend... More specifically lack of... You need a better power supply of switch to using Lipo batteries
I'm not good with pictures... and yes is a Iphone picture (just like Mr cook)
The hardware solution, it can track all the ports (0..23)
For this experience only one servo, you can see the servo in the picture is a EZ-Servo do you think 5A is short ?
The kids use a EZ/Kit lipo battery.
#15
Power supplies manufacturers never lie, right? I am still going with you don't have enough power dude... Use a 7.4 lipo battery or a larger power supply (20 amp I suggested) ... if the disconnects stop then you have your answer...
i have a 12V 10A, but t i need to get one 7v something because of the servos i don't want more cables.
But i had the idea 5A was enough how much EZB drains ?
