EZB Connect By Name icon EZB Connect By Name — Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC. Try it →
Servos Run In Wrong Directions?
I'm 3D-printing the parts to build the humanoid robot. I followed the instructions on building the robot but my own servos with metal gears run in wrong directions. For example, I told the robot to take a bow and the robot bows backwards instead of forwards. I thought that all servos MUST run in correct direction. Any suggestions?
#17
Something to consider! Ezrobot servos are designed for the platform and tolerate 7.4 volts
We can also not guarantee that reversing directions will result in the same servo positioning of after market servos.
#18
Is this correct when inverting directions?
180 - incorrect value = correct value
For example: 180 - 150 = 30
