EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
See if you can read the part number then you can see if it is in stock at places like Digi-key or Mouser.
can i use ardinio compatible servos
Servos are all the same (meaning that they are universal)... Ones that work with Arduino will also work with EZB....
So if you just have a defective IC in your servo, it is easier to just replace the complete servo. Look of one that has the same physical dimensions as the one that is defective. Look for the same operating voltage and external gear diameter as the one that is bad.
