Sound Servo (PC Mic) icon Sound Servo (PC Mic) — Maps PC microphone volume to servo positions - control multiple servos (e.g., robotic mouth) with scalar, min/max and invert options. Try it →
Set(Digital Port,On/Off) Questions
I'm having a problem getting the Set(digital port,on/off) to work. If I run this code, it works....once.
Set(1.D22,on)
Sleep(300)
servo(1.D22,90)
sleep(5000)
servo(1.D22,40)
sleep(5000)
servo(1.D22,90)
sleep(5000)
servo(1.D22,130)
sleep(5000)
servo(1.D22,90)
sleep(2500)
Set(1.D22,off)
When I run it again, the servo does not move. The code runs without any errors. The only way I can get it to work again is by shutting down the program and the EZB's and restarting. I must not be doing something right, the port is turned off by the command (i can hear that in the servo) but the Set On command doesn't turn it back on.
I clearly did not understand the Set On and Off command. Thanks Dave and Alan for explaining it and you were right, the Release command was what I needed.
