Blinkm icon Blinkm — BlinkM I2C multi-color LED control with slide dials for custom colors; supports SendI2C for custom I2C peripherals. Third-party device. Try it →
Hey danUK, there are a few options out there for controlling multiple LEDs with a few ports, one method that's gaining popularity is called Charliplexing. Charliplexing doesn't require any external components (besides resistors), you just but the LEDs in a matrix and control which LED comes on by setting some ports to inputs (High-impedance state), some to output high (5V) and some to output low (0V). Just google charliplexing and you'll get the info you need, probably check out instructables or Jimmie Rodgers' website.
Another method you could use is a Shift Register like the 74HC595 you'd just need 3 digital lines to control 8 LEDs. Anyway, good luck with your project!
Hi Skater_j10
Many thanks for the info. I'll check it out.
