Virtual Robot icon Virtual Robot — Display robot image with real-time servo position readouts and basic servo management including servo deletion Try it →
Settings button is gone in the Full Screen Video Player
Settings Button Is Gone In The Full Screen Video Player
Not a big deal nor the end of the world but I noticed in the Full Screen Video Player  there is no tab for settings ... problem?
I only have ARC (Early Access) PRO Experience the latest features and bug fixes weekly (Pro subscription required) Version 2021.03.16.00
#10   — Edited
I downloaded the latest version, I don't have the 3 dots on top to edit like you picture above in the Full Screen Video Player
Do you put this code in a script?
Ezang, install ARC early access instead of Runtime. There’s no need for you to use runtime
#12   — Edited
Good morn Dave and DJ,
I never had Runtime
I just downloaded again, did repair and modify and still I don't have the 3 dots on top to edit like you picture that is below
This picture below shows the 3 dot ... to add or edit settings
I am using V5 in the  Full Screen Video Player
You can see it says on top - ARC (Early Access) Version 2021.03.16.00
Notice it does not have the ...
I also deleted Full Screen Video Player and then restored it, no luck...
not a big deal, everything else works  :-)
That’s because that robot skill doesn’t have a configuration window. There are not supposed to be three dots. Not all robot skills have a configuration window.
#14   — Edited
Ok, I understand that
just was looking at you skill, it had the 3 dots
thanks anyway
