Hello, I have JD humanoid robot, and recently its head started shaking a lot when it moves his head. when i manually move it a little bit it stops shake. but it happens quite a lot... what can I do ?
thank you, Orit
ZAMA Emotion Model
— Valence-arousal emotion engine generating persistent, configurable robot moods and event-driven emotional outputs for expressive behaviors.
thank you, Orit
This doesn't sound like a software related issue. I recommend contacting the manufacturer of JD, which is EZ-Robot. Here's a direct link to their contact support page: https://www.ez-robot.com/Support/
Probably an issue with the little potentiometer inside the servo or it's control board. A new servo will probably fix this. Follow DJ's link and get help from the ones who stand behind your servo. Hopefully they will send you a new one.
