Pushover icon Pushover — Send robot status alerts to iOS, Android and Windows via Pushover.net. Configure User/App keys to notify on low battery, stuck or task events. Try it →
Share Bluetooth Connection With ARC
I wrote some VB code using EZ-SDK. I want to use the same Bluetooth connection ARC uses, so I don't need to rewrite every feature ARC already has. Is that possible?or did I miss it again? confused
I'm not entirely sure what you mean by this.
I assume you put together a VB program and now you want to connect to the EZB while the EZB is connected to ARC?
I don't think thats possible. Once that port is in use by one program I don't think you'll be able to access it from another.
Yea you got what I meant. I guess I need to write some code then. Thanks
