Serial Toolbox icon Serial Toolbox — EZB UART parser and Serial-TCP bridge to connect EZ-Robot cameras via Teensy USB, enabling ARC camera control and USB-to-serial bridging. Try it →
Sharp IR on car robot, table top robot avoids falling off
Sharp IR On Car Robot, Table Top Robot Avoids Falling Off
anyone know how to write this code in java?
:loop adc_wait(adc0,lower,160) stop() reverse(200,500) sleep(50) left(255,500) stop() forward() sleep(50) goto(loop)
now it starts, avoids falling off table, turns left, keeps going - cheers! All figured out below, I solved it below with help of thetechguru
thanks
Infrared indoor positioning for ARC robots: dual-camera tracks IR beacon, shows real-time heading, path and EZ-Script navigation variables
#17   — Edited
Sharp IR sensor - ARC
figured it out - now it starts, avoids falling off table, turns left, keeps going  - cheers!
How would you write this code in java? EzAng
#18
Synthiam ARC doesn't work with Java - at least not without a ton of work. You'd need to create some bridge between the two compiled executables.
Also, I don't think those sleep(50) lines are doing anything.
I ment Java script
#20   — Edited
This is probably a good way to back away from cliffs...
JavaScript Code
while (true) {
  // Wait for ever until the sensor is lower than 160
  // meaning a cliff was detected
  ADC.waitForLower(adc0, 160);
  // start moving back at speed 200
  Movement.reverse(200);
  // Continue moving back until the cliff sensor
  // no longer detects the cliff
  ADC.waitForHigher(adc0, 160);
  // And continue back a little more just in case
  sleep(1000);
  // Stop moving cause we're safe
  Movement.stop();
thanks DJ for the code
#22
Actually this makes more sense if using any NMS skills for navigating..
while (true) {
  // Instruct any  NMS navigation that we're pausing
  Navigation.SetNavigationStatusToPause();
  sleep(1000);
  Movement.stop();
  // Resume any  NMS Navigation
  Navigation.SetNavigationStatusToNavigating();
#23   — Edited
My problem was - I have a Sharp IR distance sensor, I need a Sharp Infrared Proximity Distance Sensor, ordered it
Portugal
#24
What is a the diference between "Sharp Infrared Proximity Distance Sensor" and "Sharp IR distance sensor"?
