Robotis Openmanipulatorx icon Robotis Openmanipulatorx — Inverse kinematics for Robotis OpenManipulatorX: compute joint angles and MoveTo 3D (cm) positions, supports camera-to-CM mapping for pick-and-place. Try it →
Simple Vb6 Code For Usb-Wired Video Camera.Extremely Simple
The following works with windows7 x64 w/VB6, LogitechC90 USB VideoCam Make sure the Video Camera is installed: double check it using EZB.
START A VB6 project ADD 4 buttons and rename them: cmdCapture, cmdClose, cmdExit, cmdVideoFormat ADD a picturebox: picture1
Select from MENU.PROJECT.ADDMODULE (this creates and adds a .bas file to the project) ADD the following code to the .bas module file that you just created. Then ADD the code for the 4 buttons.
Public Const ws_child As Long = &H40000000 Public Const ws_visible As Long = &H10000000 Global Const WM_USER = 1024 Global Const wm_cap_driver_connect = WM_USER + 10 Global Const wm_cap_set_preview = WM_USER + 50 Global Const WM_CAP_SET_PREVIEWRATE = WM_USER + 52 Global Const WM_CAP_DRIVER_DISCONNECT As Long = WM_USER + 11 Public Const WM_CAP_DLG_VIDEOFORMAT As Long = WM_USER + 41 Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hWnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long Declare Function capCreateCaptureWindow Lib "avicap32.dll" Alias "capCreateCaptureWindowA" (ByVal a As String, ByVal b As Long, ByVal c As Integer, ByVal d As Integer, ByVal e As Integer, ByVal f As Integer, ByVal g As Long, ByVal h As Integer) As Long
Private Sub cmdCapture_Click() Dim temp As Long hwdc = capCreateCaptureWindow("", ws_child Or ws_visible, 0, 0, 320, 240, Picture1.hWnd, 0) If (hwdc 0) Then temp = SendMessage(hwdc, wm_cap_driver_connect, 0, 0) temp = SendMessage(hwdc, wm_cap_set_preview, 1, 0) temp = SendMessage(hwdc, WM_CAP_SET_PREVIEWRATE, 30, 0) startcap = True Else MsgBox ("No Webcam found") End If End Sub
Private Sub cmdClose_Click() Dim temp As Long If startcap = True Then temp = SendMessage(hwdc, WM_CAP_DRIVER_DISCONNECT, 0&, 0&) startcap = False End If End Sub
Private Sub cmdExit_Click() Unload Me End Sub
Private Sub cmdVideoFormat_Click() Dim temp As Long If startcap = True Then temp = SendMessage(hwdc, WM_CAP_DLG_VIDEOFORMAT, 0&, 0&) End If
End Sub
Hi DJ, Yep, I did but I can't get it to run in Visual Basic 2012. Keep getting errors....But , I'll keep working on it.. Also, I get the bluetooth cam to work from ezbuiler but in the above VB6 app, If I select the wireless cam I just get a black picture box. Any ideas? EZ-Bobot:)
My suggestion is to download the latest EZ-SDK
I downloaded ez-sdk (the latest 29-01-2013) and still am unable to run it from visual basic 2012 pro. It won't load...a bunch of error messages. Anyways, I'll keep working on it and post any findings I get running.
Please read the readme.txt file in the zip archive.
