I've lost the screws to the servo and cant seem to find a thread size that works.
— Edited
Sabertooth Kangaroo
— Movement panel enabling Kangaroo & Sabertooth encoder-based speed/velocity control, UART/PC serial options, tuning and encoder setup.
How embarrassing. blush Been there, done that. Are you needing one for the new HD servos? The old EZ Servs used screws that fit Futaba Servos. This may or may not help:
Also found this about the HDD servos from a year ago. Again, may not help:
If I was a betting man I'd say this one:
Thanks Dave these are the micro servos from the store with metal gears. No nylon.
Hi Will,
It's an M3 x 6mm long Machine Screw.
THANK YOU !
Holy Cats! Looks like I guessed right! Even a blind pig finds.............................. Well you know. LOL.
Good luck Will.
