Command Duplicator icon Command Duplicator — Duplicate and synchronize commands from one master EZ-B to multiple slave EZ-Bs for simultaneous, mirrored robot actions. Try it →
Might this be for the glasses you plan to put on him? :D
yes he gets two pair if i can get them.one normal transparent and one sun glases. also the neckservo if i can get them.its 7.4 volts.from robi.
JD Head Shop Page gives the dimensions. 8cm x 8cm x 11cm
Open up the SLT from ARC in your favourite 3d software, scale the head to match the dimensions from the shop (if required) and measure the specifics to your hearts content:)
thank you blush
does any know the eyesocket dia?
i see two sound boards one is from the ez-b4 from whits one will be my voice? blush
Every control has a ? which will take you to the help page.
The Soundboard v4 is the EZ-B V4s sound board. Use the Microphone control for voice passthrough.
ez-b4 is my voice then.thanks.
