Websocket Server icon Websocket Server — WebSocket server for ARC: accepts clients, stores messages, runs per-message scripts, tracks connection status, supports debug, needs Windows admin Try it →
Skill for serial Waveshare Servos
Skill For Serial Waveshare Servos
Can you offer a RoboSkill for controlling serial Waveshare servos, e.g. type ST3215? Or are there already skills for serial servos that are compatible. E.g. Feetech serial servos
PCA9685 Servo Driver for Synthiam ARCx adds 16 hardware-timed servo outputs for hexapods, animatronics, and pan/tilt arrays.
USB
Servos 16
ADC ✕
Digital ✕
The Feetech Serial Bus servo skill in ARC is designed specifically for controlling Feetech serial bus smart servos. If you are looking to control Waveshare servos, such as the ST3215, and there is no existing robot skill for them in ARC, you can create a custom robot skill to interface with these servos.
To create a custom robot skill for your Waveshare servos, you can follow the guide provided by Synthiam on creating robot skills. The guide can be found here: https://synthiam.com/Support/Create-Robot-Skill/Overview
This guide will walk you through the process of creating a new robot skill, including how to handle communication with the servos, parse responses, and send commands. You will need to have knowledge of the communication protocol used by the Waveshare servos to develop the skill.
If the Waveshare servos use a similar communication protocol to the Feetech servos, you might be able to modify the existing Feetech Serial Bus servo skill to work with the Waveshare servos. However, this would require a good understanding of both the Feetech and Waveshare protocols and potentially some trial and error.
Remember, when creating or modifying a robot skill, you can use the ARC scripting languages (JavaScript or Python, EZ-Script, or Python) to send and receive data over serial connections, which will likely be necessary for controlling the Waveshare servos.
If you are not comfortable creating a robot skill from scratch, you may want to reach out to the Synthiam community to see if someone has already created a skill for Waveshare servos or if they can offer assistance in creating one.
@Athena do you have any feedback on this?
If the Waveshare servos are compatible with the Feetech protocol, you can indeed use the Feetech Serial Bus servo skills to control them. The two skills you've mentioned are designed for Feetech servos, but if the communication protocol is the same or similar, they may work with your Waveshare servos as well.
Here are the links to the Feetech Serial Bus servo skills for reference:
  1. Feetech Serial Bus Servo: Feetech Serial Bus servo Skill
  2. Feetech RS485 Servo: Feetech RS485 servo Skill
Before attempting to use these skills with your Waveshare servos, it's important to verify the compatibility of the communication protocols. If the protocols are not compatible, you may need to create a custom robot skill or modify an existing one to communicate with the Waveshare servos correctly.
For a full list of servo skills available in ARC, you can visit the servo Skills Overview page: Servo Skills Overview
If you need further assistance or have specific questions about the compatibility or creating a custom skill, the Synthiam community is a great resource to tap into for support and guidance.
Germany
LinkedIn YouTube
Here is some additional information about the WS servos and the performance if this servos. Even if the Feetech skill doesn't fit 100%, they can be controlled quite well. Unfortunately, feedback signals for position, current and temperature are not running yet. Nevertheless, I have a good feeling for my choice so far and you have this hobby to develop things further.
Germany
LinkedIn YouTube
Now that I finally own a Feetech servo, here is a short update on the topic of smart servo control with ARC.
To make a long story short, I couldn't tell the difference between the two servo types.
Both can be addressed in ARC, but I still couldn't get in any position feedback from either of them.
For now, I can only hope that this will be taken into account in further skill development.
Tabular presentation of my investigations:
Thanks for creating that spreadsheet, but I'm having trouble understanding what it's presenting. Are there duplicate entries for the same product with different results? Even if I understood the data, I’m unsure how it helps with reading from the servos.
The bus servos work fine for reading position and values - I’ve tested them successfully. The only drawback is that they can't release their position, making position readings useless.
As for the other RS485 servos, I have no idea. The ones they sent me don’t even work with their own software, so I can't test them. shrug
Your best bet is to contact them for answers or try speaking to someone directly from what ever company they are. They seem to be several companies? I do not understand the relationship between fintech and waveshape; just more Chinese nonsense. You could hire someone to develop robot skills for these, but without documentation or support, it’ll be a waste of time and money. If the company won’t cooperate with customer needs, there’s not much else to do. I looked into it, and I bill out at a few hundred per hour to our clients, so to give you an idea, I'm already several thousand into looking into this.
Looking at the source code for the RS485 servo robot skill, I see there’s code for the reading position. I don't know what your chart indicates, but based on the code, it should work. If it doesn’t, the company needs to provide proper documentation.
#8   — Edited
I updated the feetech 485 skill to display debug data when reading. So maybe that'll bring some insight. The response from requesting a read position should provide a debug message in the log: "Give this to DJ." Because DJ can better understand it.
