Omron HVC-P2 icon Omron HVC-P2 — Omron HVC-P/HVC-P2 ARC plugin: Python-based camera integration for body, hand and face detection, gaze, age/gender, expressions and face recognition. Try it →
Resolved Resolved by Rich!
Skipping Lines?
hello, i have been working to create a more complicated demo and am having some issues with it skipping between lines, i have found it will go from the middle of one action the the next, currently by adding sleep marks i have corrected many of these issues but i just wanted to make sure that the problem is in my inexperience programing for this robot and not a bug, i have uploaded the configuration file to the public site by accident and the demo2 script in there is what i am having issues with. also if you could take it down off the public site as it seems to have to many issues for now, i will upload it to the public site once i get the bugs all worked out
Thank you Richard
Here's a way to do it with the new EZ-Script command... If your script does not "repeat for ever" , than simply do this instead with WaitFor()...
ControlCommand("Auto Position", AutoPositionAction, "Wave")
# pause for a short period of time to ensure the action is running before we check
Sleep(500)
# now wait for the action status to change from a 1 to a 0 (true to false)
WaitFor($AutoPositionStatus = 0)
ControlCommand("Auto Position", AutoPositionAction, "Attack")
Sleep(500)
WaitForChange($AutoPositionStatus = 0)
sayezb("Done")
The variable $AutoPositionStatus stores the active status of the Auto Position. WaitFor() will wait until the provided expression is TRUE.
Forgive me for being a tad slow.... I think I get this... So $AutoPositionStatus will hold true so as long as an "Auto Position" of any type is in progress? Do I understand this correctly?
WaitFor() is going to make so many things so much easier, cleaner and more efficient! Something I wanted without even knowing I wanted it.
@Richard $AutoPositionStatus changes from 0 to 1 depending on the status of the Auto Position control. If it's carrying out an action it will be a 1 until it finishes the action then it will be a 0.
WaitFor($AutoPositionStatus = 0) will hold the script at that line until $AutoPositionStatus = 0, or in simple terms, until the action is finished.
So yes, you have that correct:)
@Rich Thanks dude... Love your new haircut by the way... But the mustache sucks....:P
I just realized that the code I posted earlier might need a slight pause after triggering the Auto Position action. This is because EZ-Script compiles and runs soooooo fast that the action may not have actually begun yet, by the time the next command in EZ-Script is executed.
So here is an update to the script example with a slight pause..
Sleep(500)
Sleep(500)
sayezb("Done")
#15
I second what Steve S said. PLease tell us more about NASA and what they use the EZB for? Thanks Chris
