Task Script icon Task Script — Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation. Try it →
New Zealand
Small Undocumented Change That May Catch Ya Out
FYI everyone
Two commands Exec ("c:\windows\notepad.exe") Browser("https://www.google.com";)
no longer seem to require the speech marks eg.
Exec (c:\windows\notepad.exe) Browser(https://www.google.com)
Took me a while to work out but all good.
Great for showing a household automation homepage or directory eg. Browser(file://10.1.1.5/volume_2/Lawrence/default.htm)
Cheers for that tameion
Commands do not "need" them, but if there are multiple parameters - they should be used.
Browser("https://www.google.ca";)
Is the correct way:)
Cool I can launch a desktop shortcut with the Exec command just use the correct file extension which is found by clicking on the icon-properties-general tab
$Tip
If you rem out a command when editing a script using # you can save the script without any errors so you can go back later and modify it without losing all your typing
Good tip winstn60! you also, D.J.
