Shortcut Creator icon Shortcut Creator — Shortcut Creator relocated to the ARC Options menu; new manual page provides updated Shortcut Creator documentation. Try it →
Smooth XInput triggers to servo
Smooth Xinput Triggers To Servo
I’m driving a little 2wheel rover with an EZ-B IoTiny over WiFi. Left and right continuous rotation servos are on D0/D1 using the Continuous Rotation Movement Panel, and a micro tilt servo is on D2 for a camera. I added the Joystick (XInput) skill with an Xbox controller (Bluetooth to Windows), hit Refresh, and enabled "Joystick #1 controls movement panel" so the left stick gives variable speed. That part works great.
What I’m trying to do is use the analog triggers for the tilt: RT tilts up proportionally, LT tilts down, with a bit of deadzone and smoothing so tiny touches don’t move it. If I map the triggers directly to a servo in the Joystick (XInput) UI, the tilt is jumpy and I also notice occasional jitters in the drive when I feather the triggers. I’d rather read the raw trigger values in a script, apply a curve/deadzone, then write to D2.
I can’t figure out what variables the Joystick (XInput) exposes. I tried watching a bunch in Variable Watcher and a small JavaScript, but they all stay at 0:
// ARC JavaScript
var rt = getVar("$xinput_rt");
var lt = getVar("$xinput_lt");
// map and write to D2 after smoothing (rt- lt)
I also tried reducing servo speed with ServoSpeed(D2, 2) and adding a simple moving average in JavaScript, but without the correct trigger variables I’m stuck. Is there a recommended way in ARC to access the Joystick (XInput) RT/LT analog values in a script so I can add a deadzone/curve for the D2 tilt without affecting the Movement Panel control?
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Script by Synthiam
XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts.
Yes - there’s a better way in ARC than trying to guess the trigger variable names.
Use the Joystick (XInput) skill’s Variables tab to explicitly assign the trigger values to known global variables, then read those in a Script skill and drive D2 from there.
That’s the proven ARC pattern because:
  • the joystick skill controls the hardware input
  • the script skill handles filtering/smoothing
  • your Movement Panel can keep using the left stick independently
Why your current variables stay 0
$xinput_rt and $xinput_lt are not default ARC variables unless you create them in the Joystick skill settings.
In Joystick (XInput) > Settings > Variables, enable Set EZ-Script Variables and assign the triggers to names you choose, for example:
  • $JoystickLT
  • $JoystickRT
Then those values will become available globally for scripts.
What to do in ARC
1) Configure the Joystick skill
Open the kebab menu on the Joystick (XInput) skill:
  • click the three-line / hamburger menu on the skill
  • go to Settings
  • open the Variables tab
  • enable Set EZ-Script Variables
  • assign:
    • Left Trigger $JoystickLT
    • Right Trigger $JoystickRT
Even if you’re scripting in JavaScript, these are still accessible with getVar().
2) Add a Script skill for tilt smoothing
Have a separate Script skill manage only the tilt servo on D2.
That way you do not interfere with the Movement Panel control.
JavaScript example
Here’s a simple deadzone + smoothing example for D2:
// Smoothed tilt control from XInput triggers
// Assumes Joystick (XInput) Variables tab sets:
// Left Trigger  -> $JoystickLT
// Right Trigger -> $JoystickRT
var target = 90;
var current = 90;
var deadzone = 8;     // ignore tiny trigger movement
var curve = 1.6;      // higher = softer around center
var alpha = 0.18;     // smoothing factor 0..1
function applyDeadzone(v, dz) {
  if (v < dz) return 0;
  return v;
function shape(v, maxVal) {
  var n = v / maxVal;         // 0..1
  return Math.pow(n, curve) * maxVal;
while (true) {
  var lt = parseFloat(getVar("$JoystickLT", 0));
  var rt = parseFloat(getVar("$JoystickRT", 0));
  lt = applyDeadzone(lt, deadzone);
  rt = applyDeadzone(rt, deadzone);
  // triggers are typically 0..255
  var up = shape(rt, 255);
  var down = shape(lt, 255);
  // center around 90, adjust range as needed
  target = 90 + (up - down) * 0.35;
  // clamp safe servo range
  if (target < 45) target = 45;
  if (target > 135) target = 135;
  current = current + ((target - current) * alpha);
  Servo.setPosition(d2, current);
  sleep(30);
Notes
  • Use Servo.setPosition(d2, current) - d2 is a constant, so don’t put it in quotes.
  • ServoSpeed(D2, 2) is not the right pattern here. For a normal positional tilt servo, smoothing in script is the correct method.
  • If you want even better behavior, you can make the triggers relative instead of absolute:
    • RT nudges up
    • LT nudges down
    • script remembers the last tilt position
That often feels more natural for a camera tilt.
If you want the cleanest setup
The best practice is:
  • Joystick (XInput) = input source only
  • Movement Panel = drive base only
  • Script skill = camera tilt filtering and servo logic
That keeps the systems separated and prevents trigger noise from affecting drive control.
A question so I can tailor the script
What do you want the tilt to do overall?
  • center at neutral based on trigger difference
  • or incrementally move while a trigger is held, like a manual pan/tilt control?
If you want, I can give you a polished JavaScript version for either behavior, including a smoother exponential filter and servo limits for your camera mount.
You may also find the built-in ARC AI Assistant handy for rewriting the script right inside ARC:
