Dialogflow icon Dialogflow — Add Google DialogFlow NLP to ARC: conversational intents, parameter prompts, scripted responses, service-account setup and programmatic robot control. Try it →
I would create a voice command that says "Look at me" and then have it pan and tilt the camera until it finds an object to track
lol duh!!!!!
i think im too excited, i need to calm down
well in one of his video, he says, "right , omni bot?" and the bot looks at him and makes noises...
so i f i ask the bot to look at me i get it, make him scan...
but what if im asking a questions or just speaking a command...
me, "hey wall-e "
wall-e, turns head to me.
doesn't look like Sures bot is scanning to find him every time. almost like, he speaks and a sensor is going off....but not a sound sensor? not sure.
im using PIR sensors on either side of the wall e
if one goes off the head turns to that direction and then the body does... would be nice if he looked at a person when they spoke.
Servos are loud but you can do this to reduce noise, dynamat or use generic peel n seal from lowest.
The Robosapien V2 I have does that. It has a sound sensor in each ear. The inside has some sound deadening foam over the sensors . I think they only work when it isn't moving. :) J.W.
