Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
So Weird : Ezb V4 Ultra Slow / Even On Ap Mode / And Some Really Weird Stuff : I
Just tried to upgrade one of my robots with EZB V4 hopping to get something much faster and also to overcome some serious issues and limitations due to EZB V3 losing Digital ports one after the other.
  1. This expensive piece of hardware does something totally unbelievable : it CHANGES MY NETWORK'S GATEWAY to its own client's address... How is it even POSSIBLE ? confused
  2. Both the EZBs' I got are EXTREMELY SLOW. If I don't disable most of the sensors connected to it, and this EVEN in AP MODE, digital ports will simply take up to 30 seconds to respond. In AP mode N mode it is a little bit faster, but still at a pace that makes running any script useless. I also varied the milisecs for all of them, even at 2 seconds delays I have some little improvement only and no one can seriously hope to use a 2 seconds delay on an IR sensor, right?
I tried from different routers, without routers (AP modes) and the only thing that will make it work properly is turning off almost all sensors (2 ulstrasounds, 3 IRs', 2 currents meters and a lux sensor).
Has anyone met the same 2 problems ? I will try to change the power source, especially the power regulator that I use and see if it does something in terms of transfer rate. For the first SO WEIRD problem, here, I'm stuck... no idea what could do that the EZB takes over the router's address on my network forcing me to set all my computers on fixed ip addesses... . It should not be possible at all.
Thanks for your help, Elfège.
In the past I have maxed out an ezb4... with multiple analog, digital reads, servos, sabretooth, etc... The only issues I have ever had was tripping the poly fuse from trying to draw too much current from the ezb... I also use a cheap $45 dlink router and still all my ezb4 projects are lightning fast with no connection issues whatsoever.... and my PC pales in comparison to your "Deep Blue 2"....:P
Is your ezb mounted near any metal? My unit was mounted in the head of my all alimony robot. Key word was. I had experienced everything you mentioned including many many disconnects at the most in opportune times. I moved the controller to a plastic plexiglass mount that is mounted to the head now leaving the controller mostly exposed. I still have issues but have just accepted them at this point. Hope this helps.
You are using a lot of ADC ports. I use all of mine and have no slow down. Like I said earlier; Only when I run the ADC monitor will my system slow down to a crawl. You don't need to run the ADC monitor window to use the ports. If you are using an ADC monitor window to view the reading of the ADC port try pausing all of them to see if our problem goes away. there is a little check box at the bottom of the window that says Pauds. Pausing the window does not pause the ADC port or them working.
Sorry Dj i saw your very detailed answer only after I had posted my last message so it may have looked like I was not reading!:) for now I'm busy with other things but I should be able to get back to it this afternoon and send you the report you asked for as well as the project's file. Thanks a lot for he great support! I'll finish reading all the posts as soon as I'm freed form current work (tons of philosophy papers to grade and comment! - my other hobby:) )
Best,
Damn ! I don't need to have all the ARC monitors to run to use the command get(adc) ? Is that right? That would indeed solve the prob!
Not really, no. For example, I only really use the actual ADC control monitors to get values when setting up scripts for sensors. After that, I delete the ADC controls.
#15
@Dj you asked earlier in this thread to communicate the router model(s) I'm unsing, regarding the DHCP bug of EZBV4.
The router which has DHCP server on my network used to be a Linksys E8350 (not really the kind of "cheap router" or "old router" that you and Alan referred to in your posts.
Now I have a brand new Netgear Nighthawk X6 R8000 and STILL THE SAME problem.
Lately, after creating a robotics class, I wanted to order 10 units of EZBV4 but I was asked not to by my School's IT director due to the fact that this issue ALSO HAPPENS ON OUR NETWORKS at school.
EZB is a great product but on that one your manufacturer messed up pretty well. It is not acceptable that such a device takes over our routers the way it does.
Here are the facts :
IF and ONLY IF my DHCP server is on the same subnet and same IP address base (192.168.1.x) THEN no problem. BUT AS SOON AS it is logged on a wifi network that uses a different subnet and/or simply a different address (like 192.168.5.x at work or 192.168.10.x at home) EZB ASSUMES that there's no DHCP server on the network.
Please, try using it on a different subnet, you'll see, the bug is systematic. This is annoying, not counting my wife yelling when she can't get Internet access on her macbook (@Alan knows that I know how to resolve that issue, it's simpler than this dhcp server issue...:):) )
Sorry for the lashing out here... but I've been trying everything for days until I found out today that this is purely due to subnet or address format difference and therefore that there's nothing I can do. I can change my infrastructure at home, but not at work... it's simply and purelly going to be a loss for you. And we are in the center of Manhattan, and a famous school and a lot of people are looking at what we do. You want me to continue using your hardware... really. Sorry to use this stick and carrot here, but this is truly unbelievable that there's still no fix for this.
Thank you for your understanding.
