ADC Value icon ADC Value — Display ADC port voltage and 0-255 linear values (0-3.3/5V); configurable board/port, units, multiplier and sample interval. Try it →
Software Question (.Net, Com, Sdk Etc.)
I am using the ez_b SDK with matlab, and trying several methods. Here are a couple questions based on my attempts:
Q1) I used the the windows SDK gacutil to load the ez_b.dll into the .net Global Assembly Cache (GAC), which it did. But when I tried to load the ez_b assembly I got this message:
"Could not load file or assembly 'EZ_B, Version=2012.4.15.0, Culture=neutral, PublicKeyToken=839146fd54f35ea1' or one of its dependencies. The system cannot find the file specified. Source: mscorlib"
I am thinking it may be a dependency, as it shows the Ez_B version and info. I see two other DLL files in your SDK where the Ez_B dll is, could those be dependencies? Is the ez_b.dll fully standalone? Any ideas? Maybe I just need to move the dll file....
Q2) I am thinking I could do this a second way, and load the shared ez_b.dll library. To do that I would need the header .h file.
Is that available?
Q3) If I want to run EZ_B as a Component Object Model (COM) server or ActiveX, I need to know the programmatic identifier. For example, when I want to start a COM server for Excel, I type this: e = actxserver ('Excel.Application').
Does EZ_B have a programmatic ID for COM? (I tried ez_b.application...)
If I can't get these to work, then I will do serial over the Bluetooth com port, but getting the interface to work would be nice.
Note: I am working with "jschreven" on this project, who has posted elsewhere in this forum related to this ("Is The Ez-b Windows Aware?").
Thanks in advance for pointers.
It appears I have the .NET working in Matlab nicely, all but actually making the servo move. Communication is working, as I can connect and disconnect etc.
So right now I am turning on the EZ-B server and using the TCPIP interface from Matlab to control the servos, which works just fine, until I can sort out my .NET issue with movement to then give me 100% control of EZ-B from Matlab, which would be awesome.
