Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
Hello.
Got a 9.6V battery i use for my ez-B. If I shall charge the batterypack with a solarpanel, how much voltage should i go for? Should I use a solar panel with 10v? or more? And what about the ampere? Is it okay with a solar panel with 0.2amp for a 0.7amp battery?
And would I need a charge regulator, or simply just a one-way diode on the positive site?
Thank you,
