Soundboard (PC) icon Soundboard (PC) — Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate. Try it →
Some Help With Ez_Ai, Roborealm And ARC
OK, Getting Alan the Android head together for the KS video. I'm asking here hoping that the few people who are working with EZ, RR and EZ-AI, can help me work thru the highlights for the video.
In the video I'd like to highlight some of the obvious ARC items, like color detection, face tracking etc. I have these set up just fine. As I get into EZ-AI I want to set up the Chatbot, which I am having trouble with the script that D.Cochran had on his video (prolly my fault). I get an error on line 5, here is the code I'm using from the video and the error:
$QueryParams = "/C"
EXEC("C:\EZ-AI\EZ-AI.exe"), $QueryParams
Sleep(3000)
:SayRobotAnswer
  waitforchange($robotanswer)
  say($robotanswer)
goto(SayRobotAnswer)
(In the above code there is a space before line 5 and 6, which i think dave said needed to be there but doesnt show here?)
> Error on line 5: Variable not defined: $robotanswer
Next up I want to set up roborealm to do object and facial recognition. I need to set up so that the object name is sent back to ARC. I got most of dave video set up but not sure the code for variable watch for incoming and how to use the data. I want the robot to be able to use the name sent back for the robot to say "hello _____" when recognized. But only once or to maybe store in database to then address the person in chatbot etc.
Then the same similar set up for object recognition, with the robot saying what an object is, if queried.
Anyone who can help with these scripts I would be grateful. We have an extremely tight deadline for KS and a calendar of things to do.
Also any ideas of what you think would be great for ALAN to highlight in the video, suggestions are open!
I probably have a million other things but this is a good start.
At family birthday party right now. I will see if you are on after this thing wraps up in about an hour.
Will, are you around? I am able to connect now and get those scripts going for you.
