Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
Some Idea For The Jd Servo Wires
hi all
i painted some ez robots and i got an idea to make ez robots look, way better with all the wires.i dont know if there's a reason why, the wires are so long.the servo wires from D0/D1/D2/D3/D12/D16 can be reduce atleast with 10 to 13 centimeters,that alot of wires less. the servo wires from D4/D7 can reduce with some 4 cm.
any ideas on this?
#19
nomad, you can connect 2 or more servos to one ez-b port. The only thing that will happen is that all servos will move together at the same time.
hi dj
i just tested two servo and idd bolt going desame direction.letterly. when the screws are on the same side,the lever will move desame direction.see pic.
