Translate icon Translate — Translate text via Microsoft Translator (auto-detect); EZ-B plugin stores translated and detected language variables. Requires Azure key. Try it →
Some more encoder
Some More Encoder
DJ hi,  I am getting some weird map results in Better Navigator using the encoder counter skill. Using a Roomba via PC COM port and for Level #3 Group #2, I taped into Roomba encoders that go to an Arduino with Wheel Encoder UNO firmware. For Level #3 Group #1, I use a RPLidar. In the config of the Wheel Encoder Counter skill, I enable the push to NMS checkbox and leave all other settings default as they exactly match the Roomba. In The Better Navigator, I use External as pose hint source. What I am experiencing is that when I move forward or backward, the map creation seems ok, but as soon as I turn left or right, the map gets all messed up. The counts from the encoders are surprisingly good. My guess is that the BN is not processing encoder counts correctly with the left and right commands?
Roomba by iRobot
Synthiam ARCx turns iRobot Roomba into a drivable robot with scripts, sensors, browser control, and AI-ready robotics skills.
Controller Dependant
Servos ✕
ADC ✕
Digital ✕
Hector SLAM navigation with NMS pose and obstacle data for room mapping, waypoints, and autonomous obstacle-avoiding routes.
#25
I can’t have a non-working product:) so I’ll have to figure it out.
#26
@Athena,
In the script editor with Better Navigator we can use "controlCommand("The Better Navigator", "StopNavigating");". Is there a "PauseNavigating" variable instead of Stop?
Yes, you can use the ControlCommand() function to pause navigation in The Better Navigator. The command you're looking for is PauseNavigating. Here's how you can use it in your script:
ControlCommand("The Better Navigator", "PauseNavigating");
This command will pause the navigation process, allowing you to resume it later if needed. If you have any more questions or need further assistance, feel free to ask!
#28   — Edited
By viewing the available control commands in ARC for the Better Navigator robot skill, Athena hallucinated that answer: You can see the available control commands for a robot skill by right-clicking in the editor or looking at the cheat sheet. The manual for the Better Navigator also has a section at the bottom that includes control commands. There is no Pause; there is only STOP. According to the manual, STOP will stop the navigation that is currently in progress.
You can instruct the NMS to pause: https://synthiam.com/Support/javascript-api/Navigation/SetNavigationStatusToPause (also see other NMS commands in the scripting manual)
If you provide more details of what you're attempting to do, that will be helpful to @Athena and myself
#29
Hahaha, Athena hallucinating. Thats funny. I am just playing around with some ultrasinic sensors. I have 3 in the front or the roomba and using the ultrasonic collision script skill. I want to detect obstacles and pause navigation and find a clear path and then resume to the waypoint.
#30
You can have the  ultrasonic sensor push it's data to the NMS. All you need to do is specify the heading the sensor is pointing relative to the front of the robot and the offset. There's filters for highest and lowest to remove false positives. Once the checkbox is checked, the sensor data will be merged with the lidar data.
But, if you want to script the "stop" yourself, I think that's what the NMS scripting commands are for.
To achieve obstacle detection and pause navigation using ultrasonic sensors, you can utilize the Navigation Messaging System (NMS) scripting commands. Here's a step-by-step guide on how to set this up:
  1. Configure Ultrasonic Sensors:
    • Ensure your ultrasonic sensors are correctly configured and positioned on the Roomba.
    • Use the Ultrasonic Collision script skill to detect obstacles.
  2. Push Data to NMS:
    • In the Ultrasonic Collision script skill, enable the option to push data to the NMS. This will allow the sensor data to be merged with the lidar data.
  3. Script to Pause Navigation:
    • Use the SetNavigationStatusToPause() command to pause navigation when an obstacle is detected. Here's an example script:
    // Check for obstacle
    if (obstacleDetected) {
        // Pause navigation
        SetNavigationStatusToPause();
        print("Navigation paused due to obstacle.");
  4. Find a Clear Path:
    • Implement logic to find a clear path. This could involve rotating the Roomba slightly to check for a clear path using the ultrasonic sensors.
  5. Resume Navigation:
    • Once a clear path is found, use the SetNavigationStatusToNavigating() command to resume navigation:
    // Check if path is clear
    if (pathIsClear) {
        // Resume navigation
        SetNavigationStatusToNavigating();
        print("Resuming navigation.");
  6. Testing:
    • Test the setup to ensure the Roomba pauses when an obstacle is detected and resumes navigation once a clear path is found.
By using the NMS scripting commands, you can effectively manage navigation pauses and resumes based on sensor input. If you have any more questions or need further assistance, feel free to ask!
#32
That is so cool, didnt know that. I jumped right to the ultra sonic collision script skill. Thank you @Athena and DJ.
