EZB Connect By Name icon EZB Connect By Name — Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC. Try it →
Sound Break Out
Sound Break Out
The bottom of my EZb V4 looks different slightly from the video I watched here for adding a 3.5mm jack. The ground hole is the same but there is only one hole with the gold colored surround in the area where I would think the power wire goes but Just want to make sure because it is slightly different from the video. Is this the spot where I would solder too?
I just got my V4 in January 2016.
Thanks for the help
Need a picture to be able to tell you. There should be 2 sets of gold circle connections. the ones closer to the middle are the ones you want, but PLEASE give us a photo to confirm.
See this tutorial. https://synthiam.com/Tutorials/UserTutorials/100/1
Which pads you use depend on whether you are going straight to a speaker (can only drive a pretty small one without distortion) or going to an amplifier (want to use the line level, not speaker outputs to prevent distortion).
I want to hook up a 3.5mm in so I can hook up my amplified speaker (beats)
I watched the video on how to do it. But like I said in my post. Where he attaches the wires look slightly different than my board. edit: From the looks of the tutorial you sent I think I found my answer. It appears the gold surround on my board is where I am looking to attach the wire.
Thank You for the tutorial link. It answered my question.
Glad my tutorial helped. This is a great mod that really makes a difference. Too bad there isn't a factory installed jack but I do understand there is only so much room and money. :)
I have another question regarding adding the 3.5mm jack.
my jack has 3 connections (left, Right, Common) The tutorial only shows a ground wire and one wire in the via.
Where does the ground wire go on the 3 prong jack? And how am I suppose to get left and right when there is only 1 wire? Do I need to jumper the prongs?
You want to attach one point to the left, and the other to ground. You should be able to disregard the right channel.
