Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
Sound Sensors
Hey Everyone!
I am currently stuck on how to code these 2 sound sensors (1 on left, 1 on the right)(picture below) on the head of my robot. I have a servo (D18) that goes up to 180 degrees and I want the head to turn towards the loudest noise level. I have looked at some examples and I still dont have any progress.
Any help would be appreciated
Thanks,
Cameron
#33
if the value is 50 from the adc reading, it makes it 5000. if it is 51, it makes it 5100. it was an attempt to get the values high enough as I didnt know what he was getting at the time. It could gave been *10 but I just set it to something in his script to see what he was getting for a value.
It may be that one mic has a lower return for some reason. He can use this multiplier to get both of them close to the same by setting one to *84 and the other one * 100 for example.
#34
Going back to the reason that this should be in two scripts like before, the motor can be tested to work correctly, which it was. The other script can be used to test the sensors and adjust a multiplier as needed for each ADC sensor.
Use this script and then follow the directions recording the values of the left and right sensor after the value is stated by the robot. This should help you determine what is going on.
saywait("Say something in front of me")
Sleep(1000)
$LevelLeft = GetADC(adc0)
$LevelRight = GetADC(adc1)
saywait("My left sensor is reporting " + $LevelLeft)
saywait("My Right sensor is reporting " +$LevelRight)
Sleep(1000)
saywait("Say something in on my right side")
sleep(1000)
Sleep(1000)
saywait("Say something in on my left side")
sleep(1000)
Sleep(1000)
#35
There is a pot on the back of the sensor. You can turn this to increase or decrease the level that is reported if the sensors are not reporting similar values when you are speaking from the front, or if the left is reporting lower than the right when speaking on the corresponding side.
Hey Everyone just wanted to touch base and say thank you for all that you guys have posted to help me. I really appreciate it.
The closest I got to set them to are:
Left Side 86 Right Side 78
I tried to adjust and made them as close as i could with the sound test script that @CochranRobotics put up and it did help. Now I just need to figure out how to adjust and multiply accordingly?
Here is the script I have been trying to still use: (Which I have messed around with numerous times and still nothing)
Servo(D18,90)
$Direction=0
$L=0
$R=0
:loop
repeat($x,0,2,1)
$Left=GetADC(adc0)*70 #adjust this value
$Left_T=$Left+$L
$L=$Left_T
$Right=GetADC(adc1)*70  #adjust this value
$Right_T=$Right+$R
$R=$Right_T
Sleep(1000)
endrepeat
$Direction=$Left_T-$Right_T
if($Direction>100)
Servo(D18,180)
Sleep(1800)
$Direction=0
$Left_T=0
$L=0
Elseif($Direction<-100)
Servo(D18,1)
Sleep(1800)
$Direction=0
$Right_T=0
$R=0
endif
$Left_T=0
$Right_T=0
$L=0
$R=0
Goto(loop)
Maybe i'm wrong... I don't think the initial idea will work.
The OP hardware is this: https://www.adafruit.com/product/1063
this is not a sound sensor, this is a microphone with an amplifier, if you read the documentation you will find:
Quote:
The output will have a DC bias of VCC/2 so when its perfectly quiet, the voltage will be a steady VCC/2 volts (it is DC coupled).
this means in a perfect scenario no sound will be 128 = VCC/2, also the value will oscillate below and above the DC Bias.
more info here: https://www.instructables.com/id/Arduino-Audio-Input/
bhouston posted a thread: https://synthiam.com/Community/Questions/6814
The hardware used is different: v2 version: https://www.dfrobot.com/wiki/index.php/Analog_Sound_Sensor_SKU:_DFR0034 v1 version https://www.dfrobot.com/wiki/index.php/Analog_Sound_Sensor_(SKU:_DFR0034) I'm not 100% sure but the amplification (check the schematic) is different is a linear value.
In the same thread, Richard mentioned an ebay sound module similar to this one: https://henrysbench.capnfatz.com/henrys-bench/arduino-sensors-and-input/arduino-sound-detection-sensor-tutorial-and-user-manual/
the sensor is different, you setup a set point, and the sensor will return a single value HIGH or LOW if the sound is above or below the set point.
If someone has a working solution, please share the hardware/script used.
#39
@ptp... Good catch man.... That would explain why simple code isn't working with it... This one should work. It has both analog and digital output and it works with 3.3V Sound sensor
#40
@ptp
Thank you for your help with that. And thank you to everyone else as well.
@Richard R thank you as well. Ill get that sensor
