Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Sound Servo Speaker Error
@DJ.
Hey buddy. I've come across a bit of a bug with the new "Sound servo Speaker" control. Running on ARC version 2015.11.25.00, when I add the control to a project, everything works fine. I added a script using the vairable and that worked too.
The problem comes when I save and close the project. When I reopen the project, I get the following error...
I close the error message and the control has disappeared. I re-add it and the same scenario happens again. I did the usual troubleshooting by running the repair/reinstall, and restarted the laptop, but no dice and the same thing still happens.
Any thoughts?
Seemed to work fine for me, at first.... I added sound servo PC speaker. I added a script to monitor $SoundValue then a speaking script... I then closed and re-opened the test project and got the same error...
That's interesting. Thanks for confirming Richard. At least I know it's not a problem my end anyway.
Thanks for the quick fix DJ.:)
