hi all is there any way of turning the volume down of the switching on and off chimes
bborastero
Gibraltar
— Edited
4 Participants
Voice Activity Detection
— Real-time microphone VAD using FFT to detect speech start/end and trigger scripts, with live level graph and sensitivity tuning
If you mean the chime the ezb makes when it boots up? Not that I am aware of... However, if you don't need sound you can remove the speaker from the ezb...
thanks but that's a bit drastic, I still want sound it's that the chimes are so loud is all
@bborastero.
Unfortunately I'm not aware of any way the EZ-B start up chimes volume can be reduced either. The only way I can suggest is to hack the EZ-B and use a sound breakout mod as explained here . With a separate amp you can manually set the volume to where you wish. But of course this may not be a suitable option for everyone (or yourself) due to different bot designs or having an unmodified Revolution bot. But it's an idea neither the less.
Or... as mentioned if you don't need the sound much, a piece of tape over the speaker opening might quiet it a bit....
Or if you do the breakout mod, you can plug in a battery powered speaker and change the speaker volume.
the breakout mod looks a bit daunting for me at the moment I think I'll leave well alone for now unless the wife really gets too p'ed off.
thanks for your help though
It would be nice to turn this down or even shut it off. I have an EZB in the leg section of my B9 and each time I start him up that chime go off and the woman says "I am connect to your network". It sounds like there's a woman in his pants and it always gets a smirk from anybody around.
I have done the breakout mod and the start up chimes and notice still sound through the on board speaker. The only way to stop it is to remove the speaker from EZB.
However it's good to know that the EZB has connected or not. That feature has helped me a few times with connection problems.
break out mod it is then thanks
