Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Resolved Resolved by Jeremie!
Soundboardez-b Background Hiss
Soundboardez-B Background Hiss
Hi everyone.
I have a small issue using the EZ-B soundboard and just wondered if anyone experienced this and possibly has a fix. When I play sound files there is a rather annoying hiss in the background.
When I play the sound files directly through a media player on my PC, perfect.
When I use SayEZB() or Pandorabot control, perfect.
But any sound file played through the EZ-B soundboard the background hiss returns. Not a major problem but I would like to eliminate this if I could. Is it possible?
Cheers.
I only get a hiss when I overdrive the volume....
I seem to be getting the hiss from anywhere between 15 to 100. I haven't gone over 100 as the sounds are loud enough.
With the breakout mod, I found much of the his was gone. I experienced hissing a bit when I had a loud song or noise playing.
Check the MP3. The built in speaker and amp isn't going to be as good as the speakers & amp on your PC, the hiss is likely to be a part of the track.
Try using Audacity (it's free) to remove hiss and see if it gives better results.
Sorry, I sould have mentioned that I broke out the EZ-B sound to play through an external amplified speaker.
Funnily enough the sound files I created where done using Audacity so it's not the MP3 quality, and any other audio such as SayEZB() ect are crystal clear.
I just got home and I tried reducing the soundboard volume down to 1, and the hiss can still be heard. In fact the volume of the hiss doesn't change when I adjust the volume slider. confused
Hi @Steve G
With the first stage audio breakout the music should be very clean. The reason your are likely seeing the voices come out clean is likely because voice is in a limited frequency range where as music is in a broader range.
A couple things to check:
Is the gain set pretty high on your external amplifier or is it just volume adjust?
Is your audio cable shielded?
Have you tried reflowing your solder joints with a bit of flux?
@Jeremie.
Thanks for responding. I don't have a separate amplifier as the speaker has one built in, so no gain control, just a volume wheel which is set to medium level. The audio cable is shielded. It came from an old pair or headphones. And the solder I used had a flux core mix so there shouldn't be a problem there.
