Joystick (Direct Input) icon Joystick (Direct Input) — DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback. Try it →
Soundboards EZB And PC
It my understanding after studying tutorials that Soundboard PC can't edit a file. Only the Soundboard EZB allows you to edit the sound file, correct?. However, I don't want the low quality sound that comes out of the controller, I want the sound to play from the PC speaker that is redirected to a bluetooth speaker. I'm trying to choreograph movement to music and the SOUNDBOARD EZB is perfect but I don't want the sound to come out of the EZB speaker. Is my only option to wire in a speaker jack into the controller?
Thanks, Brooks
JD Humanoid by EZ-Robot
Soundboard (EZB) by Synthiam
Play WAV/MP3 via EZ-B v4, manage tracks, add timed scripts for synced robot actions, control via ControlCommand(), volume and clipping indicators.
Soundboard (PC) by Synthiam
Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate.
Use SoundBoardPC control to play audio or PlayAudio("") script command and Bluetooth your device to a speaker.
Use audiocity to edit audio files
use scripting to delay between movements for chronograph
ezrobot has a good tutorial on that where professor e made robots act movie scripts
